3D-Coat 3.2 updates thread.
  • Please log in to reply
438 replies to this topic
#41 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,246 posts
  • Gender:Male
Posted 03 February 2010 - 07:47 PM
I have an 8800 GTS, you can see how it works for me in the YouTube video I posted above.
Its fast enough and screen capture must even be sucking some fps...
Maybe Maximus3D is stuck in the "twilight zone" or something.. :blink:
Maximus3d:Can you post one of your meshes?Its the only thing that hasnt been tested yet.
Phil could try it and see how it works using exact same build,with same graphic card and same mesh.
Lest limbs be reddened and rent--I spring the trap that is set--As I loose the snare you may glimpse me there--For surely you shall forget
"The Wind In the Willows", Chapter 7 "The Piper at the Gates Of Dawn"
#42 Giuseppe
Giuseppe
    Novice
  • PipPip
  • 227 posts
  • Gender:Male
i guys i have some problem but in the same room ptex perpixel e microvertex, but only if the model is lowpoly..
In hig resolutions of the obj the brushwork is quick and precise.. ythe problem is with the lowpoly model!!
I have i7 with ATI 4850
Giuseppe Albergo, CG Artist
Posted Image
#43 Maximus3D
Maximus3D
    Novice
  • PipPip
  • 149 posts
  • Gender:Male
Posted 03 February 2010 - 08:05 PM
This is not the same mesh as i used, this one has a slightly higher polycount than my mesh. But test with this and see how well it works, if it works at all..
Download
/ Magnus
#44 philnolan3d
philnolan3d
    Master
  • Moderator
  • PipPipPipPipPipPip
  • 6,544 posts
  • Gender:Male
Posted 03 February 2010 - 08:23 PM
Works just fine. Though 3DC could use a little speed up when importing models for Ptex.
Video:
http://screencast.com/t/YjJlZDY5ZDYt
Phil Nolan
Generalist
#45 Giuseppe
Giuseppe
    Novice
  • PipPip
  • 227 posts
  • Gender:Male
Posted 03 February 2010 - 08:51 PM
hi Maximus3D, your model in ptex paint works fine relly good, my problem is with the lowpoly model
Huge cage work fine, lowpoly is very slow in paint mode
Posted Image
#46 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 03 February 2010 - 09:07 PM
OK I stand corrected: 3.2.02 on Linux 64 does not have the Ptex resolution change icon. Please see attached screengrab.
It does work on Windows.
EDIT: Actually it works fine, it is just the icon _graphic_ is missing. If you click in the space below it does bring the Res controls. So it's a minor issue if you know about it :)
Cheers,
Peter B
#47 kay_Eva
kay_Eva
    Apprentice
  • PipPipPip
  • 629 posts
Posted 03 February 2010 - 10:36 PM
Download
/ Magnus
import was fast for me and painting was also fast
i'm using Cuda 64 version not sure if that has anything to do with it
"Uploading 08O. But problem - no electricity now. Notebook shows 35 min to the end of power, upload - 30. Who will be the first? :)"
#48 mwgrafx
mwgrafx
    Novice
  • PipPip
  • 102 posts
  • Gender:Male
Posted 03 February 2010 - 11:05 PM
I'm sorry but what does Ptex mean? I read no uv's for painting. How is it different from Zbrush's automatic unwrap. Sorry for the noob question, just cant wrap my brain around it.
#49 kay_Eva
kay_Eva
    Apprentice
  • PipPipPip
  • 629 posts
Posted 04 February 2010 - 12:17 AM
Well for me it means no UV unwrap, no seams in game engine (for 1st time!), and texture quality is better because the detail isn't distorted unlike when you usually unwrap things there is a slight distortion of detail depending on the unwrap.
you can see my forum pic thing to the left and there is big seams and stuff on it that appear inside of game engine idk why, but that doesn't happen anymore so that's just Ptex great
#50 Tony Nemo
Tony Nemo
    Expert
  • PipPipPipPipPip
  • 3,080 posts
  • Gender:Male
Posted 04 February 2010 - 12:57 AM
Another nice feature is the uniformity in size of the"ptels" over the whole model.
#51 Giuseppe
Giuseppe
    Novice
  • PipPip
  • 227 posts
  • Gender:Male
Posted 04 February 2010 - 01:29 AM
Hi guys my video...
in perpixelpainting with the lowpoly model my brush moves jerkily "fragments" not fluid
http://download636.m...POLY_MODEL.zipx
in ptex my brush is very fluid it's OK
http://download18.me...mymqj/PTEX.zipx
Posted Image
#52 kay_Eva
kay_Eva
    Apprentice
  • PipPipPip
  • 629 posts
Posted 04 February 2010 - 03:16 AM
Hi guys my video...
I'm pretty sure Perpixel's has always been slower with low poly. Because you have to put more texture information over a single face, but when it's high poly, you have less info to process for each polygon.
#53 splodge
splodge
    Apprentice
  • PipPipPip
  • 506 posts
Posted 04 February 2010 - 03:47 AM
Download
/ Magnus
It was totally fine with a 1024 texture size. But then when I tried it with a 4096x4096 texture then I noticed my brush strokes had become considerably slower. It was still usable though.
#54 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 04 February 2010 - 04:13 AM
I don't know if zbrush has this or not but it's also nice that yo can increase/decrease just the texture resolution in specific areas.
Phil Nolan
Generalist
#55 ShnitzelKiller
ShnitzelKiller
    Novice
  • PipPip
  • 221 posts
Posted 04 February 2010 - 07:55 AM
That is, when game engines support it. Great idea in general, only each ptex texture can only work specific to one model.
I'm also not sure how it works with triangles.
#56 kay_Eva
kay_Eva
    Apprentice
  • PipPipPip
  • 629 posts
Posted 04 February 2010 - 08:49 AM
export to game engine works fine I've already tried it, it's just like Andrew said. Looks much better than UV unwraps did
#57 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 04 February 2010 - 08:51 AM
How did you manage that?
Phil Nolan
Generalist
#58 kay_Eva
kay_Eva
    Apprentice
  • PipPipPip
  • 629 posts
Posted 04 February 2010 - 11:21 AM
File Export Model. And it works just like that.
#59 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 04 February 2010 - 01:56 PM
Oh When ShnitzelKiller said "when game engines support it" I think he meant support an actual ptex file, not just a model with UV map texture files. Obviously game engines support that.
Phil Nolan
Generalist
#60 Giuseppe
Giuseppe
    Novice
  • PipPip
  • 227 posts
  • Gender:Male
Posted 04 February 2010 - 02:59 PM
hi kay_Eva, strange, in the video i use only paint diffuse, "no normal and specularity" is difficult to paint properlys, the brush moves discontinuously :unsure:
strange
Posted Image
