3D-Coat AppLink description
  • Please log in to reply
37 replies to this topic
#1 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,837 posts
  • Gender:Male
Posted 29 April 2010 - 10:41 AM
There is possibility to interact between 3D-Coat and other applications since 3.2.11.
You may write plugin that will allow to paint some part of scene withing 3D-Coat and bring it back to your favorite App.
The description of the pipeline is attached.
Attached File  3DCAppLinkUpdated16.doc   71.5KB   97 downloads
Edit: specification updated since 3.5.01
Edit2: specifications updated again in 3.5.01+
Edit 3: specifications updated in 3.5.06, new command [curv] introduced
Edit 4: Updated to 1.3, see changes with green font
Edit 5: Updated to 1.5, see changes in orange font
Edit 6: Updated to 1.6, workfolder chnged
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#2 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 30 April 2010 - 07:05 AM
Hi Andrew,
OK cool thanks for the docs, got it working :)
It's an interesting concept, but highlights a bit of an issue I have generally with exporting. Specifically, Displacement maps aren't exported along with everything else!
Currently, I use Colour and Displacement 100% of the time, Spec maybe 60% of the time and nothing else. My shader will turn a Disp map into a Normal map if I want/need that. Sadly, I have to Export Model, go through all that, and then in addition do Texture->Export->Displace Map Visible Layers, which aside from being in a very deep nested menu, is a lot of extra work.
This import/export system certainly would speed things up... except I still have to go export the Displace Map. IMO the Displace Map should be an option in the Model Export, then everybody wins :)
In addition, and somewhat less important IMO, is an ability to "export with previous settings" so it becomes a one-button thing to Export to an app (creating the export.txt file of course) which would make for a super fast workflow.
Cheers,
Peter B
#3 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 30 April 2010 - 07:13 AM
Sorry, one more thing: The name of the textures includes the UV set, which makes sense. The problem is, that name has to be typed in when you import, so the application plugin to re-load the textures has to also have that typed in.
I can write code that scans the dir using glob or regex and ignores the uv name, but ideally there would be some way to handle this automatically.
Cheers,
Peter B
#4 Roger_K
Roger_K
    Novice
  • PipPip
  • 324 posts
  • Gender:Male
Posted 30 April 2010 - 12:37 PM
Andrew this is awesome! I'll see what I can do with 3DSMax today.
Some requests
Dont restrict this to perpixel paint. the UV Room and the other paint rooms would be viable. I allready have a script written for max which watches OBJ files
and imports UVs from them into a model without ruining the models history in max. this could be used with the UV Room.
It would be much better to be able to bipass the model loading dialog and instead pass keywords within the export.txt file to define the parameters.
eg.
mode PERPIXEL
model test.obj
imageWidth 1024
imageHeight 1024
subdivisionItterations 1
smoothUVs 1
also it would be nicer to be able to define the layers/files being worked with in export.txt. recent releases of max can work with image
stacks much like photoshop. being able to preserve the layer stack between imports/exports could be very nice.
layer myLayer
   type diffuse
   transferMode Multiply
endLayer
That which dosnt kill you can only make it easier for the next guy
i7 Quad 2.5ghz
4GB Ram
Windows 7 x64
#5 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 30 April 2010 - 07:06 PM
Great ideas Roger!
#6 3DArtist
3DArtist
    Apprentice
  • PipPipPip
  • 773 posts
  • Gender:Male
Posted 02 May 2010 - 03:42 PM
Will this allow for an external app to make changes to a model's geometry that will then be updated in 3DC? or is it just texture changes?
Intel Core i7-3770K
16GB RAM
GeForce GTX 570 2.5GB
Windows 7 Pro 64bit
web: gregcopin.com
#7 Roger_K
Roger_K
    Novice
  • PipPip
  • 324 posts
  • Gender:Male
Posted 03 May 2010 - 01:39 AM
as it is now its just a texture exchange
i7 Quad 2.5ghz
4GB Ram
Windows 7 x64
#8 Eric Cosky
Eric Cosky
    Neophyte
  • Pip
  • 88 posts
  • Gender:Male
Posted 06 May 2010 - 06:24 PM
This feature is a good idea and I appreciate the effort in this direction. Getting objects to and from 3DC is something that I think anyone having to do it on a regular basis would like to see automated as much as possible.
I have to say though, I'd much prefer to have an 3DC SDK that allowed me to control 3DC more directly via scripts. Same basic idea, but using a script interface of some sort that my plugin would create as needed for 3DC to process. A basic script interface with just a few commands could provide the applink functionality with room to grow in the future so that other aspects of 3DC could eventually be scripted.
The main benefit of this is that 3DCoat's functionality could evolve without breaking existing scripts or plugins that generate the scripts because new versions of 3DC would simply expose new commands as they were developed which older scripts of course wouldn't be using.
Python is probably a good way to go given it's cross platform capabilities. I've exposed functionality like this in applications before, it's really not too much trouble to hook up Python.
Here are some commands that would be useful (optional arguments in [] ) and I think would be just enough to support applink type functionality:
NewScene
ImportModel file.<obj|lwo>
NewLayer [Layer#]           // creates a layer after the specified layer, or on the top of the stack if unspecified.
SelectLayer Layer#
SetLayerName Name [Layer#]
SetLayerBlendMode [Standard|Multiply|Burn|etc] [Layer#]
ImportLayerColor file.png [Layer#]
ImportLayerSpecular file.png [Layer#]
ImportLayerBump file.png [Layer#]
ExportLayerColor [file.png] [Layer#]       // Uses cached filename and current layer if params not specified
ExportLayerSpecular [file.png] [Layer#]
ExportLayerBump [file.png] [Layer#]
ExportAllLayers         // uses cached filenames
We'd then be able to just create "automate3dcoat.py" which 3DC would process when it detected it. Different plugin authors could then make the import process do as many useful things as they wanted (like Roger's great idea of working with Max's layers) or in my case something more specific to Softimage's way of dealing with texture layers.
Just something to think about perhaps - I don't really expect Andrew to have time for this sort of thing but if he did I would definitely use this.
Thanks for reading
#9 Roger_K
Roger_K
    Novice
  • PipPip
  • 324 posts
  • Gender:Male
Posted 11 May 2010 - 11:31 AM
NewScene
SelectLayer Layer#
Thanks for reading
add ExportGeometry to that list of commands and it could be very awesome.
i7 Quad 2.5ghz
4GB Ram
Windows 7 x64
#10 Digital777
Digital777
    Novice
  • PipPip
  • 476 posts
  • Gender:Male
Posted 12 May 2010 - 10:02 AM
Great ideas +1 vote
#11 jwiede
jwiede
    Neophyte
  • Pip
  • 60 posts
Posted 30 May 2010 - 12:36 PM
Andrew, this doc makes reference to a file location that only exists on Windows. Where is the corresponding location on OSX (and Linux)? Can you please add that information to the document?
Thanks!
John W.
MacPro(2x2P/10.7.2),12GB,ATI HD X4870
"Who are you supposed to be? 'Topper Bottoms', the stern-yet-sensual skipper of the U.S.S. Rough Service?"
#12 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 31 May 2010 - 01:03 PM
Thanks!
In OSX & Linuxt you should store files to 3D-Coat's folder/Exchange/
You should create folder if it does not exist.
www.3d-coat.com
#13 jwiede
jwiede
    Neophyte
  • Pip
  • 60 posts
Posted 31 May 2010 - 07:55 PM
Ugh, someplace like "~/Library/Application Support/3DCoat/Exchange/" would be a much better place to put such data. By using a directory under "Applications" you run the risk of permission problems, as regular users aren't supposed to have r/w privs in Applications (admin users do, but not all users are admins in corporate environments). Similar problems exist for Linux users, and I guess "~/.3dcoat/exchange/" would be a nice equivalent location on Linux. That way, they're both in locations where even regular users have write privs.
Thanks!
John W.
#14 haikalle
haikalle
    Journeymen
  • PipPipPipPip
  • 1,371 posts
  • Gender:Male
Posted 08 June 2010 - 08:40 PM
Andrew, I know you are very busy right now, but when you have time could you add microverts and ptex into applink. Thanks.
#15 jwiede
jwiede
    Neophyte
  • Pip
  • 60 posts
Posted 09 June 2010 - 05:51 AM
One more minor request (it might be easy to do now, not quite sure): It'd be idea if we had a way to trigger an external program/script (with adjustable command line) as part of the events that occur when the user triggers AppLink on the 3DC side. I don't believe that can be done with existing features, can it?
That way, using LW as an example, we could launch Lightwave directing it to use a specific startup script that knows how to use the output file to load all the exported data. By making the command adjustable, we could also put a script in-between 3DC and the other app to do any content mgmt tasks we might want to do like checkpointing the output file, etc. If we wanted to get fancy (example for Mac, but Windows WSH as feasible), we could have it trigger an applescript that checks if the app's already launched, and if so just signals it to run the import lscript, but if LW isn't running the applescript launches it and then signals it to run the lscript.
Initially we could just get by with a preference for "what command to issue after AppLink export complete". Ideally, we'd either be able to select one of multiple app's launch profiles from a menu in prefs (allowing folks with multiple receiving apps to change which gets launched as needed, potentially even adding further automation).
John W.
#16 Eric Cosky
Eric Cosky
    Neophyte
  • Pip
  • 88 posts
  • Gender:Male
Posted 29 June 2010 - 06:42 PM
AppLink doesn't appear to be exporting the output .obj for me.
My steps:
* Create an obj
* Put the obj filename and output filename into import.txt as documented.
* Paint a bit of color
* Use the "Bring object back" menu item.
Results:
The image maps are created, but the .obj is not exported. The export.txt file has the correct filename, but there is no corresponding obj or mtl file- just the texture files get exported.
Thanks for any fixes.
PS it would be nice if it detected the resolution of the source materials and defaulted to the same resolution. I think it would also be useful if it could export to the same images files that were imported.
#17 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 04 October 2010 - 07:12 PM
AppLink specifications updated to make possible not only pipeline App->Coat->App but also Coat->App, 3.5.01 re-uploaded.
www.3d-coat.com
#18 AbnRanger
AbnRanger
    Master
  • 6,421 posts
  • Gender:Male
Posted 05 October 2010 - 01:18 PM
I'm not clear what to expect with this....are we waiting on volunteers to step in an write a link, try and do this ourselves, or will there be options in a menu to link to given programs?
#19 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 05 October 2010 - 01:48 PM
Writing of plugins started. I hired several peoples. The first one - for 3D-Max is almost ready.
www.3d-coat.com
#20 Rich_Art
Rich_Art
    Novice
  • PipPip
  • 178 posts
  • Gender:Male
Posted 05 October 2010 - 01:51 PM
Cool. IS there a connection to Cinema4D in the pipeline as well?
Peace,
Rich_Art. :good:
C4DLounge.eu our Dutch/Belgium Cinema4D Forum.
Don't forget to take a look at my Gallery here
