Smooth All ... Unexpected result ...
  • Please log in to reply
2 replies to this topic
#1 ggaliens
ggaliens
    Novice
  • PipPip
  • 374 posts
  • Gender:Male
Posted 26 September 2010 - 05:54 PM
I'm importing OBJ files from Wings3D for the burposes of
doing VOXEL CSG ops and apply shaders.
Some objects seem to spawn ERROR voxels in long strings.
This a long standing bug.
TOO BAD that Smooth all does not work recursively from parent object
downwards. Since it does not ... I'm forced to do smooth all object
by object. Pain.
If I pick the parent, I would expect some result, even if a message that
says does not work from parent.
#2 goodrichm
goodrichm
    Neophyte
  • Pip
  • 98 posts
Posted 27 September 2010 - 04:05 PM
Hi,
I recommend you send an OBJ file that causes the error directly to Andrew to: support AT 3d-coat DOT com
Also recommend you post bugs like this in the forum's "Support" section in the "Voxel sculpting bugs" area. Otherwise, Andrew might not see your bug reports.
Here are the guidelines for submitting bugs to help get them squashed quicker:
http://www.3d-coat.c...?showtopic=3224
Hope this helps...MG
<a href="http://www.voxengo.c...qq8bzWVD6"><img src="http://www.voxengo.c...fx/voxengo.png" width="180" height="60" alt="Voxengo.com" /> Pro AudioUnit and VST plugins</a>
Win 7 Ult 64bit
Intel Core 2 Quad Q9400 2.66Ghz 8GB RAM
nVidia GTS 240 2GB
#3 ggaliens
ggaliens
    Novice
  • PipPip
  • 374 posts
  • Gender:Male
Posted 28 September 2010 - 02:11 AM
This problem is not a BUG per-se. More of a complaint ... possibility for future improvement. I think it important to make that
distinction.
Also .. there is no particular geometry needed to experience what I think to be the priority complaint ... not that the VOXEL
string appears (A assume Andrew is more than well aware of that problem), but I complain more about SMOOTH ALL having no chance to act on each child of a parent object in turn.
What is this forum SECTION for anyways if not a catch all for things that don't land solidly in the BUG category.
If this forum section goes largely unread by Andrew ... perhaps it should be closed ?
