3D-Coat for OSX 64-bit [beta testing]
  • This topic is locked This topic is locked
100 replies to this topic
#61 LorenzoS
LorenzoS
    Novice
  • PipPip
  • 135 posts
  • Gender:Male
Posted 05 July 2011 - 11:27 AM
Got it. Thanks Andrew.
God is my favorite artist. He created the Heavens and the Earth!
Macbook Pro4,1 - 10.6.8 - 2gb Ram - 512mb VRAM
#62 run
run
    Neophyte
  • Pip
  • 82 posts
Posted 05 July 2011 - 04:25 PM
I was talking today with Sergyi. He tries to fix one crash (color picker) but it is hard because debugger crashes too and there is no helpful info to solve it. I asked him to make build today anyway. So he will do new build today regardless on will be this problem solved or not.
Andrew,
Just a heads up; this color picker bug, accessing the color picker causes a crash or lockup, is also in the Linux 3.5.21 build.
Jeff
#63 ifxs
ifxs
    Novice
  • PipPip
  • 387 posts
Posted 06 July 2011 - 02:24 AM
Thanks for the new build Andrew and Sergey! :-)
8x cores XEON
16+gig RAM
OSX / Linux / (and reluctantly sometimes Windows)
#64 SERGYI
SERGYI
    Developer
  • 3D-Coat Developer
  • PipPip
  • 130 posts
  • Gender:Male
Posted 13 July 2011 - 08:47 PM
Andrew,
Jeff
Thanks for your observation! The Linux package 3.5.21 has been updated today. Please download it again. Sorry for delay: Linux machine suddenly required maintenance.
#65 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 13 July 2011 - 09:19 PM
Great work SERGYI
Just asking, once more. All new OSX builds will be 64 bit ? Some confusion here. I bet they will be.
MACOSX,
3DC bug reports here:
http://www.3d-coat.com/mantis
#66 jamdalu
jamdalu
    Neophyte
  • Pip
  • 25 posts
Posted 14 July 2011 - 03:32 AM
Thank you!
#67 Psmith
Psmith
    Helper
  • Moderator
  • PipPipPipPip
  • 1,124 posts
  • Gender:Male
Posted 14 July 2011 - 05:59 AM
Michalis:
You need LiveClay because it is FAST, because it consumes minimal system resources, because it serves as the basis for the most powerful polygon tools available, because it is not wasteful (like voxels) and because it will allow for the most powerful "Smooth" tool ever designed.
You also need it because it offers you the most control over your initial mesh, (number of polygons, local density of details, precise hard edged detail).
Others need it because it allows them all the power contained within 3D-Coat without having "state of the art" hardware.
Since everything ends up as polygons - why not start that way, use them in the middle of creation - and finish with them?
Greg Smith
#68 SERGYI
SERGYI
    Developer
  • 3D-Coat Developer
  • PipPip
  • 130 posts
  • Gender:Male
Posted 14 July 2011 - 10:39 AM
Hello, michalis! It seems like there is no need in 32-bit Mac version of 3D-Coat, because Mac OS X supports 64-bit applications by default. This is not like in Windows or Linux where the user should decide which to install. So it is planned to leave only 64-bit version for Mac OS X.
#69 captainmarlowe
captainmarlowe
    Newbie
  • 3 posts
Posted 16 July 2011 - 08:35 AM
Hello to all 3D_Coat community and thanks Sergyi for bringing us 3D-Coat in 64 bits for OSX.
Works great for me so far, except for one thing (important for me), it seems that the 64 bits version doesn't recognize 3Dconnexion mouse (it worked very well in 32 bits). My graphic tablet, on the other hand, works like a charm.
Should I report it via Mantis ?
#70 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 16 July 2011 - 12:16 PM
@Sergyi
Thanks so much, you're right. I never run 32 bit now. I keep it somewhere just in case. LOL
@PSmith.
Thanks, you didn't really need to write all these. Remember I was on the beta sculptris teem.
But please, a question, have you tried to bake a dynamic tessellation or LC mesh after retopo? You're facing displacementor bumps maps having ugly triangulated artifacts. Especially on less dense areas.
I asked pixo for this as well. As, after retopo, re-projection (shrinkwrapping) looks like the original tri mesh, even it's a multi res quad mesh !
Raul, Andrew, drPetter(sc), can someone give a solution on this major problem?
Except of resculpting in vox mode or zbrush, or ridiculously smoothing in paint room of course.
MACOSX,
#71 ifxs
ifxs
    Novice
  • PipPip
  • 387 posts
Posted 17 July 2011 - 02:37 PM
@Michalis, for that issue, I've had to use the triangle edgeFlow tool in MeshMixer(such a useful tool). The ability to retain shape/volume, while arranging edgeloops on a tri-based mesh has allow for good bakes, for me anyway.... any also allowed for a much easier merging of tri's to quads when needed. ITs not a great solution, but it works for me often when I have the tri-based baking issues.
8x cores XEON
16+gig RAM
#72 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 17 July 2011 - 05:25 PM
@ifxs, I'm afraid I didn't make it clear, sorry. Have a look here, especially in shoulder area, were less dense faces are.
http://3d-coat.com/f...indpost&p=64358
Any kind of smoothing will dim sharp details and you have to resculpt them after remeshing (retopo)
These are a bit out of topic I guess. Not a OSX build issue. Not even a 3dcoat only one.
MACOSX,
#73 pavig
pavig
    Neophyte
  • Pip
  • 37 posts
  • Gender:Male
Posted 20 July 2011 - 12:48 PM
Hi all. Has anyone tested the latest 3d-coat builds under Lion?
#74 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 20 July 2011 - 03:38 PM
I won't be the first to try it. :D
But it isn't clear to me what changed in Lion. Except a few less important things and a new code that developers have to implement so to have these goodies. But not of great importance.
If graphics support is deferent, I really don't know.
MACOSX,
#75 Mykyl
Mykyl
    Novice
  • PipPip
  • 114 posts
Posted 20 July 2011 - 07:13 PM
OpenGL is now v 3.2 or whatever it is in Lion. It is a little bit more than a flashy overcoat to Lion but most features are meh. It feels smoother to me and so far had no issues with 3dcoat.
Mike
#76 SilverCity
SilverCity
    Neophyte
  • Pip
  • 69 posts
Posted 21 July 2011 - 12:21 AM
Yes, I'm wondering if the beta builds are being tested on Lion and whether we should upgrade for better stability. I'm still having some issues where a force quit will cause the entire system to go down. Is Lion better at handling these crashes and freezes?
#77 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 21 July 2011 - 09:27 AM
I noticed this. Force quit from right click on dock icon. Avoid activity monitor as it may crash the OS.
MACOSX,
#78 pavig
pavig
    Neophyte
  • Pip
  • 37 posts
  • Gender:Male
Posted 21 July 2011 - 08:24 PM
Testing 3d-coat in OSX Lion. It seems to be working fine. The nice thing is other 64 bit apps seem to be working a lot better too, making the system much more responsive. (late 2008 macbook pro with 6 gig of memory)
#79 jwiede
jwiede
    Neophyte
  • Pip
  • 60 posts
Posted 23 July 2011 - 06:56 PM
Posted this over in the regular update thread as well, but figured I'd ask here in case Mac folks are reading this instead of the other thread:
Ever since the first 64-bit beta, I've been having a problem with 3DC. It gets into this state as if the alt key is constantly held down (and yes, I've checked sticky keys, and other prefs that might cause similar effect). It doesn't always happen right away, but once it gets into this state, I can't figure out any way to get it back out again. Clicking with alt held, etc. doesn't fix it. Once in this state, I can't draw, etc. because mouse-dn dragging just rotates the view, and so forth. Has anyone else run across this problem? If so, any workarounds? It seems "new" to 64-bit 3DC, but as I've been messing around with peripherals it could as easily be an incompatibility.
John W.
MacPro(2x2P/10.7.2),12GB,ATI HD X4870
"Who are you supposed to be? 'Topper Bottoms', the stern-yet-sensual skipper of the U.S.S. Rough Service?"
#80 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 23 July 2011 - 09:26 PM
No, it doesn't happening here.
On a dual xeon nehalem + nvidia graphics OSX 10.6.8
MACOSX,
