More in cavity (Per pixel)
  • Please log in to reply
6 replies to this topic
#1 Rhino
Rhino
    Neophyte
  • Pip
  • 24 posts
Posted 24 April 2012 - 05:52 PM
I can't seem to get anything out of the 'more in cavity' option in Per pixel mode, no matter what the scale setting. Is there a trick to it or should I just stick to Microvertex mode?
#2 Psmith
Psmith
    Helper
  • Moderator
  • PipPipPipPip
  • 1,122 posts
  • Gender:Male
Posted 24 April 2012 - 06:06 PM
Make sure you are using the latest beta version and let us know if the problem persists.
Greg Smith
#3 Rhino
Rhino
    Neophyte
  • Pip
  • 24 posts
Posted 24 April 2012 - 06:33 PM
Thanks Greg - using the latest beta solved it. Now happily painting in cavities! :D
#4 carlosan
carlosan
    Master
  • Custodian
  • PipPipPipPipPipPip
  • 5,193 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 26 April 2012 - 02:46 AM
:blink:
can i ask how do you get a cavity map ?
ty
My Blogfolio
Google+ link
3DC Google+ Community
#5 Rhino
Rhino
    Neophyte
  • Pip
  • 24 posts
Posted 28 April 2012 - 11:25 AM
:blink:
ty
How do you mean, exactly? My workflow involves baking high poly model details to a low poly. I use Xnormal to bake all the maps I need, including the normal map which you can use to generate a cavity map using the tools within Xnormal.
#6 carlosan
carlosan
    Master
  • Custodian
  • 5,193 posts
  • Gender:Male
Posted 28 April 2012 - 07:00 PM
Oh i see... ^_^
Can i ask for your detailed workflow and settings ?
ty ! :)
My Blogfolio
Google+ link
#7 Rhino
Rhino
    Neophyte
  • Pip
  • 24 posts
Posted 30 April 2012 - 07:09 PM
Sure. I'm creating hard surface game assets mostly, so I....
1. Create high poly mesh in Blender or 3DS Max.
2. Import into 3DCoat (Per Pixel mode normally or Microvertex if I want to distort mesh), Auto-seam and apply UV in UV mode.
3. Paint model in Paint room (3DCoat)
4. Retopologise in retopo room (3DCoat), Auto-seam UV and export low poly mesh.
5. Export high poly model and diffuse / spec textures from paint room.
6. Import low and high poly mesh into 3DS Max or Blender and create cage for baking. Export both cage and low poly model again (to make sure vertex numbers match).
7. Bake textures in Xnormal (diffuse, ambient occlusion, normal, spec). Create cavity map from normal map in Xnormal and combine maps in Photoshop (multiply AO map onto diffuse and color burn cavity onto that).
I should get into creating/adding hard surface stuff in 3DCoat, but I haven't had time to learn properly yet.
  • carlosan likes this
