rimasson
Cloning tool improvement
4 posts in this topic
Hello Andrew.
First, congratulation to you and your wife. :)
I'd like to have a small improvement to the cloning tool.
Actually, when i disable the Additive drawing, the height of the stroke depends on the radius of the brush. It's logical.
Let's say that i closed 3D coat, started a new session, and i want to sculpt with the same height.
The solution i thought about, is to use the cloning tool, right ?
The problem is , in traslation mode, the cloning source point MOVE.
Is it possible to add a new setting to the cloning tool, with a fixed source point ?
Is it possible also to have an option to use ALL the visible layers when i'm using a tool ? (for example, as a cloning source, or when i'm using the blur tool...)
Thanks.
Francois R.
I think you can simply store preset for your sculpting tool, so you can use it next session.
Maybe it is better to make "depth picker" hotkey to pick depth from the current layer that corresponds to current pen radius? Then you can lock depth and use picked depth.
Well, if you can - go for it! :rolleyes: Its would be good addition.
