Advanced Member alvordr Posted January 4, 2013 Advanced Member Report Share Posted January 4, 2013 I find that having to click points around geometry to freeze complex areas can sometimes be less helpful than being able to freeze by geometry. If I could also have the option to pick points or faces from the actual geometry in the paint room, it would make painting/freezing, etc., a lot easier for certain things. Quote Link to comment Share on other sites More sharing options...
Javis Posted January 4, 2013 Report Share Posted January 4, 2013 Part of this already exists. In the E-panel select the triangle (this is the poly mode "brush") with freeze mode (or paint mode) you can then fill the hovered polygon with whatever tool you're using. Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted January 5, 2013 Author Advanced Member Report Share Posted January 5, 2013 Perfect! This program has so many gems, I'm loving it! Quote Link to comment Share on other sites More sharing options...
