3D Coat Forums
V4.5 BETA (experimental)
Javis,
So ditch what you said yesterday and move straight on to this new build?
Ricky.
Hi Ricky!
This build is official, definitely use this build.
Any way of tweaking metalness and glossiness parameters of the PBR shader from the Sculpt room? Looks like this shader has only color and opacity available for customization.
Is there a way to switch off the PBR , I have set the background back to vertical gradient and I can still see the effect and the reflecton from the panoramic image. Is this how it is supposed to work? I thought the lighting would go back to how it was if you reverted back to the gradient background.
Hey there folks,
Glad to see 3DCoat adapting PBR. While playing around with it today I noticed a few issues. I am using the same EXR in Unity 5 (Beta 17) and also in Substance Painter and now in 3DCoat to make sure I am using the same lighting conditions to compare. While it all looks good in Unity and Substance Painter, it doesn't in 3DCoat. The lighting has an odd green touch to it and seems generally darker. Normal maps also seem very flat currently (see image). No matter what settings I have in the shader (normal map cranked up) it always looks rather flat and uninspiring compared to Substance Painter/Designer/Unity.
What are the plans currently on exposing more light/rendering features in viewport? Is what I am looking at in the viewport rendered in Linear color space? Also, are there any plans for further post effects like Tone Mapping, etc?
I am aware that this is a first public beta. With that said I also hope that there will be performance improvements as some PBR materials act very laggy when trying to paint and I have pretty beefy hardware.
Edited by Thomas P.
Stu, you just need to apply one of the ordinary shaders to your sculpt. PBR shader will always use the envmap.
Hey there folks,
Hi Thomas!
I see what you are meaning now. Twitter is so limiting with text. Sorry! Anyway, so the problem is more obvious. When you're applying your materials, it looks like the color for them is set to "modulate" (multiplies the color of the foreground color you have selected). If you don't want that to happen make sure to go into the Material Editor and turn modulate to "Replace". It's the icon next to the color layer that looks like an asterisk, replace is a turning arrow.
Hopefully Andrew can answer your question about the extra lighting options. I hope for more options in the lighting department as well.
Hey there Javis,
Thanks for the reply! Chaning the "Modulate" to "Replace" surely did the trick color wise. Why is Modulate the standard? Should perhaps be the other way around then?
The normal map still shows very flat however as you can see in my example shot below...
Here are two videos that show the difference a bit more drastic (Painter vs 3DCoat)
Painter:  https://dl.dropboxusercontent.com/u/449179/Bugreports/DoorPainter.mp4
3DCoat: https://dl.dropboxusercontent.com/u/449179/Bugreports/Door3DCoat.mp4
Edited by Thomas P.
When can we expect the Mac version of 4.5?  I use both PC and Mac personally, but when I teach 3D-Coat in my high school classroom its all iMac's.  I was hoping to get 4.5 installed on all the machines in my lab before we return from winter break.  *fingers crossed
Hey there Javis,
I agree, replace should probably be the default.
If you don't mind PMing me your 3B file, I'll be happy to take a look at what's up with the normal map later this evening. Let me know!
I shall send you the scene. Thanks for helping/checking. On that note, I don't know how 3DCoat compresses textures if at all in viewport. Maybe that is related.
There are some weird things happening when using Sampler Tool and Pick Color/Depth/Glossiness (v-key). Try this (using both tools) when vertex painting a sphere (apply a PBR material in the Sculpt Room first):
1. Choose pure red colour, 100% glossiness and 100% metalness.
1.1. Paint a small area.
1.2. Use Sampler Tool over it and then paint another area. Note the differences.
1.3. Use the Pick Color/Depth/Glossiness on initially painted area and lay down a brush stroke. Again, note the differences.
2. Choose pure red colour, 100% glossiness and 0% metalness.
2.1. Paint a small area.
2.2. Use Sampler Tool over it and then paint another area. Note the differences.
2.3. Do the same with Pick Color/Depth/Glossiness.
3. Repeat step 2.
3.1. Use Sampler Tool over area from point 1.1.
3.2. Paint some area and note the differences.
3.3. Repeat step 2.
3.4. Use Pick Color/Depth/Glossiness over are from point 1.1.
I know sometimes when I import an obj directly into the Paint room, that for some odd reason, the normal map doesn't come along for the ride. Maybe that is what's happening for you? I end up having to import the NMap in separately. TEXTURES > IMPORT > Normal Map
I dont know if this is already solved...but everytime I select the PBR materials in the popup window it just sends me to the old material window!!!Am I doing something wrong here???
Mac/Linux versions are expected after making GL shaders. Now all shaders are DX, so only DX version works. This is main obstacle to make Mac/inux version.
I was looking at a previously painted model I had made without pbr, in the paint room/ window and it was being lit by the image ,I thought I would be able to switch it off.
Anyway ,I have gone back to 17d for now ,because exporting crashes all the time.
Gonna have to paint my "boob armour" a different way for now......
The most crashes during export is, if you want to overwrite files.
Delete all older files and you dont get an crash on export.
Thanks, but I have been making a brand new folder for my tests, so no overwriting.
I did manage to get something exported but I cannot figure out how to apply my textures in Carrara to make it look like the model in 3dcoat. I think this pbr thing is designed to work for game engine type stuff....which I know nothing about.
Maybe Carrara is to old now . How would one export a pbr painted model to Maya or Max? Is it possible . If someone can do that maybe I can extrapolate that method for Carrara.
Yes the textures are for Games or Render Engines that support PBR like Marmorset.
To use it in different Render Engines you have to setup your Material, Shaders and Textures correctly.
Sad, that my hint solved your problem. On my side it works as usual if i dont overwrite files.
Anyway.
First, could anybody confirm if the Bake with Name Correspondence is no longer working, please?
I dont get any results if i use that option.
Second, i am no longer able to edit Values like the Dedail of LC or in the Brush Options.
I only could work with Mouse&Drag but not able to enter a value.
Could anybody confirm that bugs.
Edited by Malo
Does carrara have nodes and shaders that support pbr? The traditional diffuse, spec, gloss materials in most 3d appz are not compatible with pbr. But most node based appz(3dmax, maya, lightwave) can replicate pbr when the scene is set up for it.
Yea, I just checked and it's broken.
Reported: http://3d-coat.com/mantis/view.php?id=1694
Edited by ajz3d
I guess it does not support pbr. I wanted to export a nice worn paint on metal I did that looked really good. I can do it in carrara ,it involves shader mixers and masks . But it is a bit complicated and I always forget how to do it.
Carlosan... I tried those options , but the key thing is ,I dont know what to do with the resulting maps in Carrara. Plus that top option was one of the crashes I had. But the Gloss /Metalness exported ONCE, but I had no luck in Carrara.
I think the main problem is I aint smart enough!! Thanks for chipping in everybody.
