Is there a trade of with voxels and pixel paint when it comes to PBR?
probiner
Seems to me that voxels paint doesn't show normal/height displacement and that pixel pain doesn't show reflections but just colored spec.
Is this true? There's no way to see all channels at play yet?
pixel pain does relief: http://prntscr.com/5pl5dn
voxel paint does reflections: http://prntscr.com/5pl6pr (relief channel always empty)
Can't have both though... -_-'
Sorry if this is known, first time I tested 3DC PBR.
Cheers
Edited by probiner
Ah, ok, true,I though it used to be called Voxel Room  :) But you're right, the tricky part is that Voxels are converted to Surface on the fly when you go to the paint room. Had no idea.
Anyways, I was looking forward more for per pixel painting relief, since it captures details better than SF vertex paint.
Plus I noticed that the cavity map generated for dense SF isn't that useful for PBR painting: http://prntscr.com/5ptv1s
Thanks
just load an environment map,per pixel painting reflectivity works fine.
Where do I actually load these maps by the way?
Thanks
Edited by probiner
