Member Daniel Tynan Posted June 9, 2015 Member Report Share Posted June 9, 2015 The stamps tool is completely missing from 4.5 I looked very carefully through the popups menu and whole interface. .nowhere to be found. Has the name been changed? I guess I'll install 4.5.03 to see if it is in there. Need to use it to apply a decal image to my model for client. Thanks Daniel Quote Link to comment Share on other sites More sharing options...
Javis Posted June 9, 2015 Report Share Posted June 9, 2015 Hi there! Sounds like you're referring to the old Materials. They are now called Smart Materials, and can still be used in the same fashion they were before by applying only depth, gloss and color to it. If you were referring to the Stamp Stroke Modes, those are both still there in the Stroke Mode panel (top of the left tool bar, or "E" key). Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 9, 2015 Report Share Posted June 9, 2015 Related hope it help Quote Link to comment Share on other sites More sharing options...
Member Daniel Tynan Posted June 11, 2015 Author Member Report Share Posted June 11, 2015 Thanks for the replies. I am talking about the "Stamps" tab that used to be next to the "Stencils" tab. You used it similar to the way you used stencils but to stamp color images onto you model. Here is what it looked like: http://www.hostingpics.net/viewer.php?id=614641Capturede769cran20150607a768132550.jpg so looking at the link Carlosan sent me. . do I need to now create a new smart material and load up my image I want to stamp through one of the nodes in the smart material and then set mapping mode to "from camera"? This is a very different workflow from the old stamps tab where you would just create a new stamp and load up the image you want. Quote Link to comment Share on other sites More sharing options...
