New Member wupto Posted June 20, 2015 New Member Report Share Posted June 20, 2015 Hi everyone, I'm wondering if there is an easy way to stack islands when they have the same element, like in this example, I made a tree with many leaves and the UV map would look like this: http://i.imgur.com/A72DcZL.png So if I would do that manually I had to scale and move every single island and it would not only take a long time but also never really be accurate (http://i.imgur.com/mjWIKHf.png). Is there any way to do this better? Or at least a way to scale all the islands equally so I'd only have to move them manually? If not, maybe in another program like 3ds max? Thanks! Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted June 20, 2015 Solution Report Share Posted June 20, 2015 Hi! Select an island Ctrl + C Select another island Ctrl + V 2 Quote Link to comment Share on other sites More sharing options...
New Member wupto Posted June 20, 2015 Author New Member Report Share Posted June 20, 2015 Thanks a lot! Quote Link to comment Share on other sites More sharing options...
New Member Nivellen Posted September 12, 2016 New Member Report Share Posted September 12, 2016 In 4.7.06 works fine for simple islands, but it doesn't for more complex one, like in this picture. Any help plese?door by Leszek, on Flickr Quote Link to comment Share on other sites More sharing options...
New Member Palle Posted September 13, 2016 New Member Report Share Posted September 13, 2016 I have the same kind of problem. I'm going to blender now every time I need to snap island on top of each other. Quote Link to comment Share on other sites More sharing options...
Member Percevan Posted September 13, 2016 Member Report Share Posted September 13, 2016 (edited) In my experience, it works even on complex uv islands. That being said, I'd advise to recheck the topology, if you can't stack UV island by copy/pasting, it's generally because of split components, or too differing triangulation. In Nivellen's case, for example, I'd bet on the later. Having the same triangulation should let the usual UV stacking works, after rotating some of those differing edges (select / edge /CW or CWW spin command). Or, since it's so similar, delete one UV island, select the other and clone it (*), position the cloned retopo parts,and easily copy paste their Island. Might be faster than picking incorrectly rotated triangle edges edges and rotating them one by one. (*) / edit: Still in the Retopo room of course; And 'clone' "appears" in the Commands tab if you're first in Select mode, Faces. Edited September 13, 2016 by Percevan precision on workflow & avoiding double-post Quote Link to comment Share on other sites More sharing options...
