Member kritskiy Posted July 7, 2015 Member Report Share Posted July 7, 2015 Hi everyone, Can you please tell me if there's a way to change the opacity the same way size/depth is adjusted. Maybe it's possible to switch depth (RMB + vertical drag) with opacity? There's a Alt+mouse wheel hotkey in preferences, but I'm using tablet and therefore I don't have mouse wheel. Thanks! Quote Link to comment Share on other sites More sharing options...
Solution PolyHertz Posted July 7, 2015 Solution Report Share Posted July 7, 2015 You can have Opacity linked to RMB drag via the "customize navigation" menu, but you would have to give up both size and depth to do it. Quote Link to comment Share on other sites More sharing options...
Member kritskiy Posted July 8, 2015 Author Member Report Share Posted July 8, 2015 Thanks, PolyHertz! I had no idea about this menu, it's super amazing! I ended up setting MMB+drag for opacity since I use similar to Maya navigation and don't use MMB on its own. Quote Link to comment Share on other sites More sharing options...
New Member Subpablo Posted December 4, 2018 New Member Report Share Posted December 4, 2018 For anyone else who found this thread while looking for a solution to this issue, there's now an option to swap horizontal/vertical drag control to Brush size/opacity like so: I also recommend turning down Vertical speed with this setting (.25 for example). 2 Quote Link to comment Share on other sites More sharing options...
