Member illbleed Posted July 11, 2015 Member Report Share Posted July 11, 2015 Hi, When i right click and open up smart material editor.. i hit reset so i can return back the colors it originally had and instead it gives me this weird block under my smart material. I have no idea how to bring them back and closing and opening just opens up with this every time. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 11, 2015 Report Share Posted July 11, 2015 Hi Smart Material Properties Your Preferred Mapping Selection is cubemapping ? Quote Link to comment Share on other sites More sharing options...
Member illbleed Posted July 11, 2015 Author Member Report Share Posted July 11, 2015 Hi Smart Material Properties Your Preferred Mapping Selection is cubemapping ? Um let me check. I haven't changed anything besides hitting reset because i changed a color. Edit: It looks like it was set to camera. Now that i switched it, the material is still gone. it switched back to the icon it was before though. Instead of having the fabric material, it turned to a pure dark red. Quote Link to comment Share on other sites More sharing options...
Member kevjon Posted July 11, 2015 Member Report Share Posted July 11, 2015 Try Right click on material & "Restore factory defaults". To get the normal icon you will have to change its mapping to cube mapping as carlo says. Quote Link to comment Share on other sites More sharing options...
Member illbleed Posted July 12, 2015 Author Member Report Share Posted July 12, 2015 Try Right click on material & "Restore factory defaults". To get the normal icon you will have to change its mapping to cube mapping as carlo says. That just makes it like it shows up on the image i attached. For some odd reason it just shows a gradient red and gradient black instead of the actual material. Quote Link to comment Share on other sites More sharing options...
Member kevjon Posted July 12, 2015 Member Report Share Posted July 12, 2015 (edited) Right click on material and set the preferred mapping to cube mapping. Does that fix the icon ? If you change to cube mapping in preview options, that won't work. Edited July 12, 2015 by kevjon Quote Link to comment Share on other sites More sharing options...
Member illbleed Posted July 17, 2015 Author Member Report Share Posted July 17, 2015 Right click on material and set the preferred mapping to cube mapping. Does that fix the icon ? If you change to cube mapping in preview options, that won't work. It fixes the icon issue, but the smart material is still gone. This is what it looks like. I haven't changed any of the files. Quote Link to comment Share on other sites More sharing options...
Member Magic Man Posted March 7, 2016 Member Report Share Posted March 7, 2016 I'm having the same problem as the topic creator. I want to reset a smart material and I set up cube mapping as has been suggested before, but the smart material is gone now and only its silhouette remains. Has anyone found a solution for this issue? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 7, 2016 Report Share Posted March 7, 2016 Are the textures on the same path location ? Quote Link to comment Share on other sites More sharing options...
Member Magic Man Posted March 7, 2016 Member Report Share Posted March 7, 2016 No, the path location for the smart material texture was wrong so I changed it to this path inside the smart material editor: C:\Users\[uSERNAME]\Documents\3D-CoatV45\patterns\cartoon The thumb for the smart material has been regenerated now by 3D-Coat, but it has not returned to its original state as you can see in this picture: The original material had more layers before I decided to reset it, but now it has only one. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 7, 2016 Report Share Posted March 7, 2016 Hope this help cartoon.zip 1 Quote Link to comment Share on other sites More sharing options...
Member Solution Magic Man Posted March 7, 2016 Member Solution Report Share Posted March 7, 2016 Thanks for the help, carlosan! I copied the cartoon folder that you supplied to my patterns folder and got the original wood material back. I'll make sure to always duplicate a smart material before I make any changes to it from now on Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 7, 2016 Report Share Posted March 7, 2016 Glad to help Always a reinstall could back all the default files If you have custom content or need to share SMaterials, there is a tool that let to export it as package 1 Quote Link to comment Share on other sites More sharing options...
Member x-OL Posted September 2, 2016 Member Report Share Posted September 2, 2016 I have a similar problem too. It occurred with few default smart materials Where I can download all packs of default Smart-materials. I want to reinstall they all. Is it possible? Quote Link to comment Share on other sites More sharing options...
Member Kirch Posted December 24, 2017 Member Report Share Posted December 24, 2017 I think my problem is similar... I just installed 4.8.07, current version, hoping to find the smart materials. I only have three materials in the default tab of the smart materials. Not sure where to look or how to reload/show the smart materials that come with 3dc. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 25, 2017 Report Share Posted December 25, 2017 Take a look at C:\Users\user\Documents How many folders 3D-CoatV4___ are there ? Use the command Migration Master to copy from previous installation to current one. Quote Link to comment Share on other sites More sharing options...
