New Member Debrovski.. Posted August 22, 2015 New Member Report Share Posted August 22, 2015 Hi, everyone! I am new in 3DC and i need help. I am trying to project this hi-res tileable pattern to small part of low-res texture(lol). Yes, i understand it is imposible to get nice result , but i have no choise coz of memory limit. Anyway, i get better results from "classic" apps like GIMP. Pattern. Results I think the reason is method of texture interpolation while texture resizing, i can choose several in GIMP like "Cubic", "Linear", but i dont see it in 3DC =( Thanks in advance Quote Link to comment Share on other sites More sharing options...
Javis Posted August 23, 2015 Report Share Posted August 23, 2015 Hi! You are correct in the interpolation method. It can be changed to other methods pretty easily. When you're using a Smart Material, there is a popup that has all of the methods, in a drop down list. The drop down list on the bottom left of the Smart Material popup, by default it should say "Cube Mapping". Let me know if that helps. Quote Link to comment Share on other sites More sharing options...
New Member Debrovski.. Posted August 23, 2015 Author New Member Report Share Posted August 23, 2015 Hi, Javis! Thanks for your reply, but it seems you dont understand my problem correctly, it is not about mapping, so i've made clear example for you OK, so i have a simple plane, with 256x256 texture: And this huge 3600x3600 texture Then i import it in 3DC as new material, choose "From Camera" mapping method, go to orthographic top view and start painting it on the plane: Final result: But if i just resize this 3600x3600 texture to 256x256 in GIMP, result is much better: Problem is that my future models will consist of hundreds of separated small UV-islands to rationally occupy limited texture space, so it is just impossible to work in 2D apps like Photoshop or GIMP... So generally, i need 3DC to draw hi-res to low-res texture without these weird distortions Quote Link to comment Share on other sites More sharing options...
Javis Posted August 25, 2015 Report Share Posted August 25, 2015 Gotcha! Thanks for taking the time to make such a great example. I'll pass this to Andrew, I think he'll have an idea of how to do implement something like this in 3DC. Cheers! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 27, 2015 Report Share Posted August 27, 2015 just downsample hires textures twice. Mipmapped projection of textures is still not done... Quote Link to comment Share on other sites More sharing options...
