Advanced Member ozukaru Posted October 14, 2015 Advanced Member Report Share Posted October 14, 2015 (edited) I post this here for visibility instead that the specific forum because I think is important... The default "Normal Map Software Preset" in Preferences is "Unreal Engine" And the default value for "Normal Calculation Method" is "Angle Weighted Normals" That produces this normal map (first image) for a simple box kind of panel. That seems to be ok in UE4 but some artifacts appears when a "build lights" is performed there (I made sure this is totally unrelated to the infamous secondary uv channel need of unreal light-maps) as you can see in the left panel in the third image. If I change the "Normal Calculation Method" to "3D-Coat Normals" then it works perfect! as you can see in the second image and in the third, in the right panel. So I suggest that you 3d-coat developer/staff change that setting ("Normal Map Calculation Method") to default "3D-Coat Normals" if/when the "Normal Map Software Preset" is set to "Unreal Engine" so people like me don't waste time trying to figure out things, please Thanks Edited October 14, 2015 by ozukaru Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 14, 2015 Report Share Posted October 14, 2015 Will you please send your suggestion to Andrew Shpagin atsupport@3d-coat.com ty ! //edit hope this help https://www.youtube.com/watch?v=U-Y261KBQS4 Quote Link to comment Share on other sites More sharing options...
Advanced Member ozukaru Posted October 14, 2015 Author Advanced Member Report Share Posted October 14, 2015 thanks, im doing more testing, it seems my model in particular has a problem such that it changes radically the normal map when the method of calculation changes... Im testing with a cube now and the normal maps looks almost identical whichever method I chose... Quote Link to comment Share on other sites More sharing options...
