Member DaveMW Posted October 23, 2015 Member Report Share Posted October 23, 2015 So I just bought 3DCoat and I'm trying to use a wacom tablet. Unfortunately the right click zooming is nearly impossible to get around. It's jumping all over the place. Anyone have a work around or fix for this? Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted October 23, 2015 Contributor Report Share Posted October 23, 2015 Greetings and welcome to the community. From your tablet setup (control panel --> wacom) change the pan and zoom and assign them to the desired buttons. Sensitivity can also be adjusted. Quote Link to comment Share on other sites More sharing options...
Member DaveMW Posted October 23, 2015 Author Member Report Share Posted October 23, 2015 Hey thanks for the response. I have remapped the buttons several times it's more along the lines of the act of zooming. It's like it doesn't understand whether to zoom in or out so I just get this jiggle back and forth. I'll try reinstalling the drivers and adjusting the sensitivity. Do people actually use wacom tablets in 3DCoat? Quote Link to comment Share on other sites More sharing options...
Javis Posted October 23, 2015 Report Share Posted October 23, 2015 Exclusively use a tablet. I never use a mouse with 3DC. Fwiw the issue you're reporting is the first I've heard of it. What OS, tablet and video card are you using? Sent from my SM-G900P using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted October 23, 2015 Contributor Report Share Posted October 23, 2015 Same here , only tablet. This problem if i remember and understand correctly i had it too. I stopped the pen windows service and it stopped but that was the very first issue i had with 3d coat (pen issue in general). Quote Link to comment Share on other sites More sharing options...
Member DaveMW Posted October 23, 2015 Author Member Report Share Posted October 23, 2015 Hmmm I'll try that tonight. I'll edit my post when it's fixed. Quote Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted October 23, 2015 Advanced Member Report Share Posted October 23, 2015 Fwiw the issue you're reporting is the first I've heard of it. What OS, tablet and video card are you using?No, I have this too (it started in versions after 4.5), without hardware changes or recent modification of Windows services. It is a very massive malfunction, one simply can't work without proper Zoom Funktion. I reported in the Beta thread. Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted October 24, 2015 Advanced Member Report Share Posted October 24, 2015 I have used my Wacom Bamboo for the last five years, working great with 3dcoat . Though i have also had intermitant probs with the windows services( though not for ages now). What used to happen with me was that when I switched on my computer a little square would pop up that said "Tablet Driver Not Loaded" or something similar . The pen would sort of still work but not go to the edge of the screen.I finally figured out if I went to windows services I could restart from there. But generally my little Bamboo is great.( two of the little lights on it dont work now ! but I think the buttons still do, but I never use them anyway....) Quote Link to comment Share on other sites More sharing options...
Member Solution DaveMW Posted October 27, 2015 Author Member Solution Report Share Posted October 27, 2015 Ok so here is how I fixed my frustrating zooming problem w/ my Intuos4 tablet. I went into the tablet properties>tool>Grip Pen>Options... and switched the right click from "hover" to "click and tap". Works phenomenally. Quote Link to comment Share on other sites More sharing options...
Member ShaneO Posted October 29, 2015 Member Report Share Posted October 29, 2015 In a semi-related question... how do you guys set up your wacom pen to navigate with 3DCoat? If I have the default 3DCoat navigation, and the default Pen settings, I can Orbit and Zoom, but I cannot Pan. With the mouse, panning is a MMB function. So I'm wondering how you have it set up. I'm coming from Zbrush land. I'm not asking for the same functionality as that, just what you guys prefer. Thanks in advance! -ShaneO P.S... If you are tired of the constant windows tablet popups, rings, flicks, and all of those annoyances... someone wrote a great little script to get rid of it all. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 29, 2015 Reputable Contributor Report Share Posted October 29, 2015 In a semi-related question... how do you guys set up your wacom pen to navigate with 3DCoat? If I have the default 3DCoat navigation, and the default Pen settings, I can Orbit and Zoom, but I cannot Pan. With the mouse, panning is a MMB function. So I'm wondering how you have it set up. I'm coming from Zbrush land. I'm not asking for the same functionality as that, just what you guys prefer. Thanks in advance! -ShaneO P.S... If you are tired of the constant windows tablet popups, rings, flicks, and all of those annoyances... someone wrote a great little script to get rid of it all. I have the stylus button closest to the user/eraser assigned the MMB and it works pretty well. Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted October 29, 2015 Advanced Member Report Share Posted October 29, 2015 Hey Shane, I'm not sure if it will help, but make sure you have your navigation settings as follows in 3D Coat. You can find the settings in the Camera dropdown. Camera-->Customize Navigation Then make sure you have one setting that is RMB + LMB is set to Move in Screen Space. 1 Quote Link to comment Share on other sites More sharing options...
