PBR materials to Cinema 4d
ScottyT
  • New Member
Hi there!
I absolutely love the PBR materials in 3D coat, the problem is transferring them to cinema 4d and getting the same look... Does anyone have a method of linking up the exported maps in cinema to get the same appearance?
I have Arnold, Vray and standard C4D renderers... Any help would be much appreciated!
  • New Member
Thanks Neophyte, that plugin looks awesome!
I do think it is surprising that there is not a standard workflow for using the exported maps in the popular render engines... It would really open up the full potential of these excellent PBR materials
  • 10 months later...
3D-Coat supports three different PBR workflows:
    Gloss/Color Specular
    Gloss/Metalness
    Roughness/Metalness
If you are working PBR Metallic/Roughnes.
Cinema Version: R17
-create a new material
-open the material editor
Base color, Normal, hight
-feed the base color texture in the input in the color tab
-do the same for bump and normal in their tabs
The tricky part
-delete the legacy specular layer
-create a new GGX layer
Specular:
-feed the specular into the Layer Color texture input
Glossiness:
-under the roughness bracket create a colorizer
-feed the glossiness map into the input
-invert the map by changing the gradient to white and black
GGX
-change the GGX properties, highlighted yellow on the image. Tweak the roughness aswell
Hope this will help you
