Advanced Member kenmo Posted February 5, 2016 Advanced Member Report Share Posted February 5, 2016 Hi... In the painting room I used photo textures as stamps in 3DC v4.1 to texture my UV mapped models. I do not see stamps in 3DC v 4.5. I do see stencils but I am unable to use the color of the photo texture when painting. It defaults to the color white. In v 4.1, if I changed my default color to white, the brush would then use the colors of the texture. It doesn't work this way on stencils in v 4.5. Where are stamps in v 4.5? Can anyone help me? Thanks kindly Ken Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted February 5, 2016 Reputable Contributor Solution Report Share Posted February 5, 2016 They were renamed Smart Materials in 4.5, because of the PBR tech. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted February 5, 2016 Advanced Member Report Share Posted February 5, 2016 smart materials put load in your image there .I would make a separate category and name it for all your photos. You could also load in your color image in as a Alpha brush up top right and then use the stamp or constant pressure turn the falloff to zero white is full color I also use this to inlay to mesh depth of say 5 % . 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted February 6, 2016 Author Advanced Member Report Share Posted February 6, 2016 Many thanks guys...appreciate it.... Quote Link to comment Share on other sites More sharing options...
