Unity and linear color space?
Not much info on this one in Unity Answers, so I thought that I would ask you, guys.
Has anybody managed to enforce linear space on mobile devices (Android, for example) either with scripts or some 3rd party stuff? It's weird that Unity doesn't support it by default, because without it PBR shading doesn't make much sense.
Edited by ajz3d
yes with an asset i always get linear for Android
Its called Go linear but unfortunately (just checked for you ) it went depricated
https://www.assetstore.unity3d.com/en/#!/content/13167
Edited by Michaelgdrs
Yes, this is something quite frustrating. Assets look pretty terrible in gamma color space and Unity aren't clear on when/ whether this will ever be implemented. I asked the same question and was recommended to use sigmoid color correction curves to achieve a similar effect to linear.
@Michael. Yes, the GO Linear isn't even available for download anymore. :(
@Arumiat, thanks for the info. So you apply sigmoid (which are the default curve shape) curves to RGB channels of Color Correction Curves camera effect? Also, when using this method, do you linearize your albedo first or just feed in the sRGB version?
Edited by ajz3d
Its a camera effect , it will change the color in camera space to match linear.
Doing the same with another asset unfortunately it also became deprecated.
Bulding for PC only the last year so i didnt have to look more into it.
But any camera space color correction will work.
I've only ever applied the color correction curves straight to the sRGB version and assets certainly looked better. I did this without understanding the mechanics behind why they might look better. I haven't tried linearising the textures (although I've heard of this), - if you know of a good resource that describes how to do this would be great to hear.
Here was my Unity thread.
I'm building for webGL and you're building for Android, so performance of these effects is of course pretty important to us both. I'm not sure if using a LUT is faster than curves, will have to do some investigations on that at some stage.
I'm linearizing my albedo maps in Houdini. From what I noticed, linearization doesn't produce identical results to the true linear workflow available on every platform other than Android, iOS and WebGL (I compared the results with PC's linear setting), but it's pretty close.
Color correction image effect had way to much impact (for a shader) on a frame rate. I noticed a drop from 58 to 33 frames per second (average on SM-N9005) just because of that effect. That's totally unacceptable.
  • 5 months later...
Again confirms using PBR with gamma is not a good idea.
If I was to go back to painting in 3DC with the old workflow (pre PBR), anyone know the viewport/ shader settings that would be appropriate?
Also azj3d, it would be cool if you get a screencast of how you linearise your albedo maps, if that produces a good effect
Thanks,
T
  • 4 weeks later...
I have something better to share. Unity beta version (5.5.0b10):
Graphics: Add linear rendering on Android with OpenGL ES 3.x and iOS with Metal.
Source: https://unity3d.com/unity/beta
