Advanced Member do lo Posted May 12, 2016 Advanced Member Report Share Posted May 12, 2016 i suggest a see through capability like zbrush has. where you can use a slider to see through the whole screen onto the main desktop...and no excuses just do it! hah! Link to comment Share on other sites More sharing options...
Carlosan Posted May 12, 2016 Report Share Posted May 12, 2016 Ways to Help: Work on Feature Requests Writing proposals is a bit of an art form in itself, and pretty difficult to do right! Asking for a copy of a feature in another application is almost always wrong because it doesn’t tell us the most important thing: What we primarily need like to know is HOW you intend to use the feature. This is the most important part. All features are carefully considered in terms of the workflow they affect, and we will not start working on any feature unless we know why it is useful and how it is exactly used. Even better, once we know how it’s used, we as developers can start thinking about what else we can do to make the workflow even more fluid! Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 12, 2016 Contributor Report Share Posted May 12, 2016 You can 'ghost' the model over a background image or have a transparent image over the model. Doesn't that cover it? Link to comment Share on other sites More sharing options...
Carlosan Posted May 12, 2016 Report Share Posted May 12, 2016 ZBrush has a global setting which defines the transparency of the entire ZBrush application. This See-through slider, located at the top right of the ZBrush UI allows you to see the desktop or other windows through the ZBrush window. Was a quick way to display image references. Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 12, 2016 Contributor Report Share Posted May 12, 2016 A freebie named "Floaty" creates a window with your image over your work and can be worked through. Very handy. Link to comment Share on other sites More sharing options...
Advanced Member do lo Posted May 16, 2016 Author Advanced Member Report Share Posted May 16, 2016 A freebie named "Floaty" creates a window with your image over your work and can be worked through. Very handy. sounds nice. to bad i have to use external freebees. should be included. hopefully it will. Link to comment Share on other sites More sharing options...
Carlosan Posted May 17, 2016 Report Share Posted May 17, 2016 This discussion does not add anything more.Closed. Link to comment Share on other sites More sharing options...
