New Member seengh Posted August 1, 2016 New Member Report Share Posted August 1, 2016 Hello, I recently purchased 3D Coat and started my first personal test project. I opened up the software and created a model in the sculpt room, then brought it into Paint Room and painted it. At this point, I tried to save out the object with all the aesthetic data and started to run into problems. 1) Tutorials show that when you go to Export objects and textures, it is supposed to give you a popup menu of the types of maps you want to save. This pop up doesn't appear. It only allows me to save the geometry as an obj, fbx, etc. 2) So, I go to Texture drop down and try to save everything manually one channel at a time. All the tga files come out black. Any insight to fixing this would be greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 2, 2016 Report Share Posted August 2, 2016 Hi ! You painted the model after retopo o are you painting polypaint ? Quote Link to comment Share on other sites More sharing options...
