Member urahziel Posted September 19, 2016 Member Report Share Posted September 19, 2016 Hi Guys, my Problem is, when i look at my "Smart Material Preview" with "Cube Mapping" everything is fine, but when i fill the layer, the material has another much bigger scaling. So I need to scale every material really small and try blindly. The strange is, this wasn't at the beginning. At first everything was fine, but after working some hours this behaviour occured. A restart didn't change anything, also the problem occur on new files. Is this a bug or an option which i accidently activate? I'ts now the second time I have this problem. Last time I fixed this issue with reinstalling 3d Coat and deleting any associate file, but this is not really a nice solution. Can anyone help me? 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 19, 2016 Report Share Posted September 19, 2016 Hi ! Im shooting in the dark... Sculpt Room Geometry > Scene Scale is = 1.00 ? 1 Quote Link to comment Share on other sites More sharing options...
Member urahziel Posted September 20, 2016 Author Member Report Share Posted September 20, 2016 The Scene Scale changed the scaling, but it's not like the preview. I tested a little more and realized, there is even more broken. The Results after "Refill Material" are all identical by the following mapping settings: "From Camera", "Cube Mapping", "Cylindrical" and "Spherical". The only distinct mapping is "UV-Mapping". Also the "UV-Mapping" is the only one with the correct result in correspondence to the preview. And there is even more, you can see an offset by any UV-Border. I suppose there is something broken and 3d Coat is using "UV-Mapping" for every mapping settings... The whole behaviour works fine, when I paint with the brush and don't use the "Refill Material" option. But how can this happen after some hours of work? It worked correctly at the beginning. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 20, 2016 Report Share Posted September 20, 2016 Are you using the last version 4.7.10 ? If not please try installing it please Quote Link to comment Share on other sites More sharing options...
Member urahziel Posted September 21, 2016 Author Member Report Share Posted September 21, 2016 No, I was using the version 4.7.06. After installing the newer version, "Cylindrical" and "Spherical" are working correctly again, but "Cube Mapping" is working wrong as mentioned before. Quote Link to comment Share on other sites More sharing options...
Member urahziel Posted October 7, 2016 Author Member Report Share Posted October 7, 2016 Problem still there and makes texturing to a real pain Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 7, 2016 Report Share Posted October 7, 2016 Are you using the last version 4.7.11 ? If not please try installing it please Quote Link to comment Share on other sites More sharing options...
Member urahziel Posted October 7, 2016 Author Member Report Share Posted October 7, 2016 Yes I do. Quote Link to comment Share on other sites More sharing options...
