Member ryivhnn Posted October 22, 2016 Member Report Share Posted October 22, 2016 How do you make the brush only sculpt faces facing the camera? If I zoom in too close it happily scrawls all over rear faces instead of the small fiddly bit I actually want to sculpt on This has been an irritation for the fingernails but has made doing anything inside the mouth cavity impossible. Thanks Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted October 22, 2016 Contributor Report Share Posted October 22, 2016 A picture always helps, but you may need to "Hide" parts that are in front of your work. Quote Link to comment Share on other sites More sharing options...
Member ryivhnn Posted October 22, 2016 Author Member Report Share Posted October 22, 2016 I couldn't come up with something that would illustrate the problem at the time, sorry XD Of course I worked out how I could have done one now and will do that if problem persists. I'll try the hide thing, thanks (once I find it again, I'm sure I saw something about hiding when I was doing something completely unrelated) Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted October 23, 2016 Contributor Report Share Posted October 23, 2016 Hidung parts of the volume is done in Sculpt and hiding part of retopo mesh in Retopo (a selection). Quote Link to comment Share on other sites More sharing options...
