[Solved] Import multi objects from ".Obj" file as multi voxels
Ratchet
Hi,
For example i have a space ship in one ".obj" file, composed of two separate objects like wings and engine,
it is possible to import each separate object of the file as a new Voxel object in the Voxel tree ?
This would import automatically Wings sub obj as a new Voxel object and Engine sub obj as a new Voxel object in the Voxel tree.
This could be usefull when we import multi parts objects to Voxels and be able to start working on each part individually, instead of doing thousands of imports when the model has lot of sub objects.
Thank you.
