Advanced Member sculptactive Posted December 2, 2016 Advanced Member Report Share Posted December 2, 2016 (edited) Why are the measurements not consistent between 3DC and Modo. It seems to convert Millimetres to Metres. Attached is a approx 199mm SQ box created in 3DC. When I export the object to Modo it imports as a 199.0006m box Anyone else had this issue? Edited December 2, 2016 by sculptactive Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 2, 2016 Report Share Posted December 2, 2016 Sculpt Room > Geometry Define Measurement units Which are your current units in 3DC ? Quote Link to comment Share on other sites More sharing options...
Advanced Member sculptactive Posted December 2, 2016 Author Advanced Member Report Share Posted December 2, 2016 40 minutes ago, Carlosan said: Sculpt Room > Geometry Define Measurement units Which are your current units in 3DC ? Same as yours mm, so it should be the same in Modo, but it is not. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 2, 2016 Report Share Posted December 2, 2016 The Scene Scale is = 1 ? Quote Link to comment Share on other sites More sharing options...
Advanced Member sculptactive Posted December 2, 2016 Author Advanced Member Report Share Posted December 2, 2016 (edited) 3 hours ago, Carlosan said: The Scene Scale is = 1 ? Funny mine are set to -0.000000 Not sure what difference it makes on export as the size is still in metres in Modo? . Edited December 2, 2016 by sculptactive Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 3, 2016 Report Share Posted December 3, 2016 You can use measure tool and change units or scene scale to get equivalent size. Quote Link to comment Share on other sites More sharing options...
