Advanced Member micro26 Posted December 4, 2016 Advanced Member Report Share Posted December 4, 2016 Hi, When i add a primitive after another they dont have the previous location and orientation could we have a check to stick to the latest position? Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 4, 2016 Report Share Posted December 4, 2016 +1 Workaround: Drag the primitive layer to Models Windows. Any new model added keep location and orientation. Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 4, 2016 Author Advanced Member Report Share Posted December 4, 2016 (edited) Thanks Carlosan youre right , one quick question when i import a model with the "on brush" option there is an offset(distance) as i hover the cursor do you know how to fix that? Edited December 4, 2016 by micro26 Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 6, 2016 Author Advanced Member Report Share Posted December 6, 2016 sry to bump but really i need the on brush option ... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 6, 2016 Report Share Posted December 6, 2016 Switch this sets ON help your workflow ? Click to Place Scale to brush radius Use Stroke Direction Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 7, 2016 Author Advanced Member Report Share Posted December 7, 2016 YES thats it thx Carlosan Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 7, 2016 Reputable Contributor Report Share Posted December 7, 2016 On 12/4/2016 at 3:06 PM, micro26 said: Thanks Carlosan youre right , one quick question when i import a model with the "on brush" option there is an offset(distance) as i hover the cursor do you know how to fix that? When using the IMPORT tool > ON BRUSH, you can adjust the offset by RMB + Dragging your cursor to set it on the fly 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 7, 2016 Author Advanced Member Report Share Posted December 7, 2016 5 hours ago, AbnRanger said: When using the IMPORT tool > ON BRUSH, you can adjust the offset by RMB + Dragging your cursor to set it on the fly With RMB + drag you adjust the depth of the imported mesh while hovering with your mouse but the offset i m refering to not just the depth but also the other 2 axis. The objects that i made to be used as "brushes" were created with correct 0,0 pivot but the on brush option ignores it for some reason. I noticed that its not happening on all models(not brushes) and also there is no offset when using custom meshes via the primitives tab. In the picture i attach a custom mesh that is not getting the brush scale and has offset on placement Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 7, 2016 Reputable Contributor Report Share Posted December 7, 2016 Maybe the mesh you are trying to apply it onto, is so low poly that there are no verts nearby to adhere to? Just a guess, if it works on other models. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 7, 2016 Report Share Posted December 7, 2016 Before import it... is the mesh at 0,0,0 center in global space ? (on your original app) Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 8, 2016 Author Advanced Member Report Share Posted December 8, 2016 Yeap like i said it was created on 0,0. On the exaple image tha object was created inside 3dcoat. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 8, 2016 Report Share Posted December 8, 2016 Please can you share the model ? Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 8, 2016 Author Advanced Member Report Share Posted December 8, 2016 brush_mesh.obj Here it is . Placement works on the default starting voxel scenes but not on others. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 8, 2016 Report Share Posted December 8, 2016 Hi ! I was testing your mesh on another project and cant replicate the error, sorry. I found that the model scale is huge, but this should not interfere with importation. What if you import the mesh as model using Primitives tool and Models window popup ? Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 8, 2016 Author Advanced Member Report Share Posted December 8, 2016 (edited) Like i said ,if i use the Primitives tool it works fine issue is only with import tool. Edited December 8, 2016 by micro26 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 8, 2016 Reputable Contributor Report Share Posted December 8, 2016 1 hour ago, micro26 said: Like i said ,if i use the Primitives tool it works fine issue is only with import tool. Like I said before, if the surface you are trying to place it on, has just a few polys, it probably won't behave like you expect. Increase the resolution on the object and just as it worked in the video above, it should work on your object. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 8, 2016 Report Share Posted December 8, 2016 i was testing import tool too and cant replicate this issue. how many polys your base mesh have ? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 8, 2016 Reputable Contributor Report Share Posted December 8, 2016 23 minutes ago, Carlosan said: i was testing import tool too and cant replicate this issue. how many polys your base mesh have ? I tested the ON BRUSH part of the IMPORT tool and on extremely low polygon surfaces (a lot of modelers leave large single polygons for large flat surfaces), it is indeed unpredictable, but that is likely because 3D Coat is looking for the nearest vertex to use it's normals. When there isn't one nearby, 3D Coat is like "hey man....what do you want from me? Give me a vertex so I know what you want me to do." Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 9, 2016 Author Advanced Member Report Share Posted December 9, 2016 I have a feeling maybe its scene thing (scale or something).test.3b Its my scene with everything deleted and only a sphere drawn. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 9, 2016 Reputable Contributor Report Share Posted December 9, 2016 Go to the GEOMETRY Menu > EDIT SCENE SCALE. Probably should be reset to x-0,y-0,z-0 and 1 unit scale Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted December 9, 2016 Author Advanced Member Report Share Posted December 9, 2016 (edited) 13 minutes ago, AbnRanger said: Go to the GEOMETRY Menu > EDIT SCENE SCALE. Probably should be reset to x-0,y-0,z-0 and 1 unit scale When was added ? :P Finally thx man thats it. Thanks for your time. Edited December 9, 2016 by micro26 1 Quote Link to comment Share on other sites More sharing options...
