Member Beddall Posted December 16, 2016 Member Report Share Posted December 16, 2016 Hey, When using the quad tool in the retopo room. Is there a way to tweak vertices without exiting the tool?. So far I can only manage to move edges with the RMB. cheers Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted December 16, 2016 Contributor Report Share Posted December 16, 2016 Unless something has changed since I last used it, the answer is 'no'. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted December 7, 2017 Advanced Member Report Share Posted December 7, 2017 Has this changed in the meantime? Being able to move vertices directly in quad mode would be much more useful to me than moving edges. Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted January 11, 2018 Advanced Member Report Share Posted January 11, 2018 Doing retopo again and stumbling over this very problem once more. What"s the usual workflow, here? Moving edges doesn't seem to make any sense to me. I'm constantly switching tools for small corrections. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 11, 2018 Reputable Contributor Report Share Posted January 11, 2018 4 hours ago, Findus said: Doing retopo again and stumbling over this very problem once more. What"s the usual workflow, here? Moving edges doesn't seem to make any sense to me. I'm constantly switching tools for small corrections. It would be a good idea to add a feature request for this, to Andrew. I have usually just worked around it (switching tools). In the meantime, the best way to handle it is to use the POINTS & FACES Tool, with has the ability to switch tools on the fly by holding down the CTRL or CTRL + SHIFT key combination. So, you could choose the QUADS tool with the CTRL key held down. Then when you need to move a vert, release the CTRL key then RMB drag the vert. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted January 11, 2018 Advanced Member Report Share Posted January 11, 2018 Thanks, AbnRanger! Should I write an email to Andrew? (Can"t write in the feature request forum.) Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 11, 2018 Reputable Contributor Report Share Posted January 11, 2018 5 hours ago, Findus said: Thanks, AbnRanger! Should I write an email to Andrew? (Can"t write in the feature request forum.) Yes. Email support@3dcoat.com, to make the request and mention why it's important. I think the reason it moves edges is because that is essentially what the Quads tool is. It is an EDGE Extrusion tool, thus RMB dragging moves edges. Add/Split and Points/Faces work on the vertex level. That's the logic behind it, but I agree with your suggestion. Many times I've wanted to move a vertex in that tool and have to switch to something else to do that. Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted January 11, 2018 Advanced Member Report Share Posted January 11, 2018 Done Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 13, 2018 Report Share Posted January 13, 2018 Ok, done it in next build. 3 Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted January 15, 2018 Advanced Member Report Share Posted January 15, 2018 And many thanks again! Quote Link to comment Share on other sites More sharing options...
