[Solved] Error when painting mesh
No I'm going through New --> Paint UV Mapped Mesh --> File --> Change size there
I'm noticing that it's only occurring a particular part of my model which are the doors, not the frame. I've also tried Importing the door as a separate mesh to the door frame, and again its only happening on the door. I've tried various texture sizes and it seems to only be happening on a 2k texture, even 4k size works fine. Here are some images to clarify.
ps please note the size of the door itself in respect to the grid, when I import it it appears to be larger than intended? All these imports are OBJ. I've also performed a fresh install.
Before import assign a material in your external app, this solve the issue.
Door.obj
If i begin the project at 1K and change the resolution to 2K using the command
Paint Room > Edit Mesh > paint and texture resolution
everything is ok.
But... if i import model For Paint  pixel painting selecting texture size 2k, some issues occurring.
Confirmed and bug reported.
ty
Doorwithmaterial.mtl
Doorwithmaterial.obj
Btw I've used "lock normals" and "unlock normals" within maya 2016 and exported as obj again, and in both cases it no longer causes issues.
Door_lockednormals.obj
Door_unlockednormals.obj
Actually just tried with it combine still happening, i'll just leave it for now and move on
Edited by LaidbackLemur
