Member Wybie Posted January 24, 2017 Member Report Share Posted January 24, 2017 Hi guys, Someone knows how to make alpha from an object in (3D-Coat 4.7) like MRGB ZGrabber di Zbrush? I try to change my workflow shifting all definitively on Linux. Thank so much!! Quote Link to comment Share on other sites More sharing options...
Advanced Member ebitz Posted January 25, 2017 Advanced Member Report Share Posted January 25, 2017 In the main menu of 3d coat, File-Export-Export Depth along Y. Just make sure your model is orientated to the global Y axis. Plug in settings in dialog and save. 3D coat will export a normal, color and exr. The exr file will contain the alpha info. 2 Quote Link to comment Share on other sites More sharing options...
Member Wybie Posted January 25, 2017 Author Member Report Share Posted January 25, 2017 11 minutes ago, ebitz said: In the main menu of 3d coat, File-Export-Export Depth along Y. Many many many thanks Ebitz! That's amazing. Quote Link to comment Share on other sites More sharing options...
