Member StefanoCiarrocchi Posted February 20, 2017 Member Report Share Posted February 20, 2017 Hi there curve tool doesn't create any kind of curve, or points to control the curve when I click on the geometry; same problem with the text tool, no text is created when clicking. The geometry is active and visible, both in polgon or voxel mode.... Any suggestion how to fix it? Thanks in advance 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 20, 2017 Report Share Posted February 20, 2017 Hi The latest release is 4.7.24 Can you test that one ? Ty Quote Link to comment Share on other sites More sharing options...
Member StefanoCiarrocchi Posted February 20, 2017 Author Member Report Share Posted February 20, 2017 (edited) Hi Carlosn thanks for your reply......I was thinking about a stupid error, simply because 3 days ago everything was ok....and I found it. As you can see in the image above, "Invert shift action" is active, so it draws the curve only when i keep the shift pressed....shame on me.... please delete this post and thanks again for your support Edited February 20, 2017 by StefanoCiarrocchi 1 Quote Link to comment Share on other sites More sharing options...
Member StefanoCiarrocchi Posted February 20, 2017 Author Member Report Share Posted February 20, 2017 can I add another question? I'm cutting some geometry in voxel mode, and the tool icon is a huge yellow circle, as in the image, that slow down a lot the performance of 3d coat.... how can I decrese the radius of the tool? in the upper bar there is no size settings ... thanks again in advance Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted February 20, 2017 Contributor Report Share Posted February 20, 2017 Use the '[' key to shrink and the ']' to increase the radius. Quote Link to comment Share on other sites More sharing options...
Member StefanoCiarrocchi Posted February 21, 2017 Author Member Report Share Posted February 21, 2017 Thanks for your reply Tony, unfortunately I have the italian(maybe this is his name) keyboard and the square brackets doesn't work directly, they need a combination of Alt Gr + key, so at the end the shortcut don't work. Do you know where can i set this parameter on another shortcut? thanks again! Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted February 21, 2017 Contributor Report Share Posted February 21, 2017 (edited) Using the 'End' key over the "Radius" field in the upper tool parameters (almost any other tool will show it) may allow you to create a shortcut. But the cutoff tool doesn't need a radius setting because it uses the selection rectangle or lasso to designate a part for deletion. Use the 'E' key to see your choices. Edited February 21, 2017 by Tony Nemo typo 1 Quote Link to comment Share on other sites More sharing options...
