Kitbashing
I copy the kitbash meshes (obj) to specific folders located in the 3D-Coat Program/Application folder (depending on your OS), under VoxStamps/Objects/nameyourfolderhere
Then use models or splines to add it to the scene
And transform or pose tool to follow the base sculpt mesh
Tool option > on pen is a great option to use too
I meant if you create your own models as part of your workflow and whether you do it inside 3d coat or in other 3d application.
Edit: more specifically, how suitable is 3d coat for making kitbash sets to reuse within 3d coat.
Edited by Sebastián Benítez
Addendum
I noticed there appear to be two locations to add stuff like kitbash models on my computer :
Some are installed here
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps
And other here
C:\Program Files\3D-Coat-V4.7.24X\VoxStamps
Which is correct? Are both required?
I find installing stuff in the same folder as the application very messy and frustrating. Each time there is an upgrade to 3DC I have to re-install all the voxstamps, splines, materials, stencils, etc to the new Program Files folder.
Would it not be better just to have a standard folder in my documents that is independent of 3DCoat version?
ie: C:\Users\kenmo\Documents\3D-Coat\VoxStamps
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps  is dated Nov 13, 2016 and this is where the TinkerObjects are installed
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps\Objects\_TinkerObjects
C:\Program Files\3D-Coat-V4.7.24X\VpxStamps is dated Feb 17, 2017
So which path is the correct or default location? It appears to be OK to use both...
  • 7 months later...
