biscuitguy
bake
couldn't bake normal map
8 posts in this topic
Hi there,
I'm trying to bake my sculpt model to low poly mesh by "Bake w/ Normal Map (Per-Pixel)" but baked maps has strong noises on any Materials.
this is sculpt mesh. (sorry for poor mesh, this is my best.)
and this is baked mesh on Paint room. diffuse and normal map have strong noise.. (it should say dithering?)
what happen on my 3d-coat?
I'm using ver4.7.26(GL)
Alienware 17 R2 w/windows8.1 64bit
thanks,
Hi !
Show voxels in paint room is = off ?
Hi, Carlosan.
ya, voxels is hide on Paint room.
I tried another file or simply voxel, but I got same result...
The texture resolution is low ?
How is packed your UVmap ?
Bake normals with dithering is = ON ?
look like resolution was not affect to noise. (but size is change)
and UV also not affect. (I tried copy and paste as maximum scale to new UV a piece of mesh)
Bake normals with dithering, I tried both, but seems like no effects on my mesh.
I tried export voxels and retopo meshes to new scene, but it happened again.
totally no idea. :(
I had this problem also.
To fix it you will have to adjust the normal intensity on your pbr sculpt shader.  For some reason the bake results are really strong compared to what you expect.
I think it has something to do with the way the shader resolution is tied to the density of of the sculpt layer.
Anyways, if you turn down the bumpiness on your shader it should give you better results.  You can also try adjusting the texture scale to see if that helps.  Reducing 'bumpiness' value prior to baking should do the trick though.
hi, gbball.
surely I changed scale voxel mesh. now I lend to colleague my laptop whose install 3d-coat, so I'll check shader after she is back.
Posted (edited)
Sorry, to be more clear...you'll have to right click on the pbr shader you're using for the sculpt object and adjust the bumpiness setting on the shader...you don't need to change your sculpt resolution.  bumpiness.gif
Edited by gbball
