Member MechChicken Posted April 15, 2017 Member Report Share Posted April 15, 2017 My freehand skills aren't quite on level yet Suppose I have a cube. Instead of drawing on a face, is it possible to place points on it and it will create a line for me, change the width of the line, maybe even make a rounded corner, and then choose a boolean op such as substract? What I basically like, is to have a clean, straight trench. And because I'm a vector graphic designer, this would come natural to me. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 15, 2017 Report Share Posted April 15, 2017 Hope this help Quote Link to comment Share on other sites More sharing options...
Member MechChicken Posted April 15, 2017 Author Member Report Share Posted April 15, 2017 57 minutes ago, Carlosan said: Hope this help Thanks, this helps a lot. I wonder though, why is it based in the paint room? Aside from painting with color, the options related to depth/extrude, wouldn't those be logical to have available in the sculpt room? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 15, 2017 Reputable Contributor Report Share Posted April 15, 2017 (edited) 1 hour ago, MechChicken said: Thanks, this helps a lot. I wonder though, why is it based in the paint room? Aside from painting with color, the options related to depth/extrude, wouldn't those be logical to have available in the sculpt room? Check out the spline tools available in the E-panel. Check out each one and you will see which one will work for your intended purposes. I highlighted border, that has some effect on some tools. Depth limit is pretty well says what it means. Use with some tools. Just test out the tool set, it will not take you long to figure how they work. Also you can load eps and other file formats from the load shape tab in the E-panel Depth limit works good with say the cut off tool to limit the depth cut. Edited April 15, 2017 by digman Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 15, 2017 Report Share Posted April 15, 2017 You can use the same technique in sculpt room too Quote Link to comment Share on other sites More sharing options...
Member MechChicken Posted April 16, 2017 Author Member Report Share Posted April 16, 2017 @digman @Carlosan oke thanks, will try all suggestions. Quote Link to comment Share on other sites More sharing options...
