Member pr1970 Posted April 21, 2017 Member Report Share Posted April 21, 2017 Hey All, I have an AO layer aswell as color, metalness and roughness layers below. I would like the AO layer to occlude the specular shine from the metalness/roughness. It works for the color but am I missing something as i cant find anywhere how to do the same for roughness/metalness to stop it being shiny in the dark areas of the AO map? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Member pr1970 Posted April 24, 2017 Author Member Report Share Posted April 24, 2017 Anyone help? Thanks Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 24, 2017 Reputable Contributor Report Share Posted April 24, 2017 (edited) Yeah, sometimes it takes a while to get an question answered by volunteer helpers at the fourm. Sometimes we miss a post or busy with our own work. Plus at times I have to go do life duties for a month or so. In the PBR workflow, AO does not block the metallic or the roughness. That should be taken care of with your Metallic and roughness maps... Generally AO is not required for PBR rendering as it introduces baked lighting into the texture. It can be used with artistic discretion of course. Some smart materials require a AO to be generated when " more on lit or more on shadow" are used as one of the conditions but you do not have to export it unless it is needed... Edited April 24, 2017 by digman 2 Quote Link to comment Share on other sites More sharing options...
Member pr1970 Posted April 24, 2017 Author Member Report Share Posted April 24, 2017 ok thanks digman. So essentially I can just combine the AO with the roughness map in photoshop to what is desired. Quote Link to comment Share on other sites More sharing options...
