Member SIgor Posted May 1, 2017 Member Report Share Posted May 1, 2017 Hi guys, is there a way to install extensions on another DRIVE instead on C? I was manage to install 3D Coat on another drive but when I install extensions, they are saved by default in the DOCUMENTS section of C DRIVE on Windows. So is there a way to change that? Thanks, Igor Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted May 1, 2017 Contributor Report Share Posted May 1, 2017 (edited) Create a symbolic link that points from your Documents\3D-CoatV47 folder to a place on another drive. Edited May 1, 2017 by ajz3d 1 Quote Link to comment Share on other sites More sharing options...
Member SIgor Posted May 2, 2017 Author Member Report Share Posted May 2, 2017 11 hours ago, ajz3d said: Create a symbolic link that points from your Documents\3D-CoatV47 folder to a place on another drive. Hi ajz3D, thanks for the reply. But I am not sure how to do that, any suggestions? Cheers, Igor Quote Link to comment Share on other sites More sharing options...
Contributor Solution ajz3d Posted May 2, 2017 Contributor Solution Report Share Posted May 2, 2017 Here's some nice info about this type of links: https://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/ 2 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted May 2, 2017 Contributor Report Share Posted May 2, 2017 Doing the exact same thing on another ssd , works like a charm Quote Link to comment Share on other sites More sharing options...
Member SIgor Posted May 2, 2017 Author Member Report Share Posted May 2, 2017 3 hours ago, ajz3d said: Here's some nice info about this type of links: https://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/ Thanks a lot! Cheers Quote Link to comment Share on other sites More sharing options...
