Followers 0
Aleksey
mesh does not match to exported mesh ( polygon numbers)
6 posts in this topic
Posted (edited)
I export a mesh from cinema 4d, fbx, open it, uv map it, export it back as fbx, open it in cinema. Now this mesh it properly uv'ed but i can't apply the uv map to my existing mesh, because the polygon numbers dont match up. This wasnt an issue before :( not sure which version broke it.
also i notice it welds overlapping points, since less points come back in then there where. but welding beforehand doesn't solve the issue either.
Edited by Aleksey
having same problem with another mesh.
here is screens shot. on the left is original mesh, on right is mesh i brought back in from 3d coat. I copied the uv tag to old mesh. and this is what i got..
and polygon selections mess up ( meant to be on nose and ears)
At export window, is Use source position = ON ?
it was off, tried it with it turned on, same issue. :(
these are my export settings ( they look different from yours)
I think it was working until this preset stuff was added.
also that checkbox keeps getting unticked. even if i save a new preset
Followers 0
