New Member Bradimus Posted May 28, 2017 New Member Report Share Posted May 28, 2017 I am running into a problem each time I use the Autopo Wizard and get to the 'strokes' part. Whenever I draw a path the resulting stroke will not follow the curve I set. It will only produce straight lines. I have added a gif for your convenience. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 28, 2017 Contributor Report Share Posted May 28, 2017 It looks like it won't work if areas are 'frozen'. In the Sculpt room, Freeze menu>Unfreeze all. Quote Link to comment Share on other sites More sharing options...
New Member Bradimus Posted May 31, 2017 Author New Member Report Share Posted May 31, 2017 On 5/28/2017 at 8:28 AM, Tony Nemo said: It looks like it won't work if areas are 'frozen'. In the Sculpt room, Freeze menu>Unfreeze all. Thanks for the reply. First, unfreezing removes everything from the first step of the Autopo process, which is to freeze areas that you want to have higher detail. Second, I tried what you suggested as well and the strokes only creates strait lines still. Could this be an issue of size? I just noticed that I have to zoom way in to make the model show up. If so, is there a way to normalize the size? In ZBrush and Maya the size is correct so it seems odd that it would be a size issue. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 31, 2017 Report Share Posted May 31, 2017 I suppose the model is very tiny. Try changing scene scale -this are the default values- or keep the size using more segments and spline point density Hope this help. Quote Link to comment Share on other sites More sharing options...
