symetrical retopo
dnhart13
  • New Member
Hi... its day-3 for me trial on 3dcoat...
just done sculpting and still do retopology for now... theres some trouble i cant find an answer.
when you do retopo with symmetry ON..
1. can you completely turn OFF mid snapping ? in some casses you just dont need snapping... like overlap cartoon eyes
2. flip object on 3dcoat
3. bridge between 2 edges
Thanks b4
Hi and welcome!
1. Yes. There is a snapping tolerance on the top bar of the application. You could also turn symmetry off when you get close to these areas.
2. More information is needed to properly answer your question. Could you explain more detail what you're needing? :)
3. The easiest way to bridge to edges is with the "Quads" tool, which has a bridge equivalent preset in the top bar , there is a drop down list called "Edge Extrusion Method", change this to "Parallel". Then click one of the edges you want to bridge, then click the second edge.
