[Solved] Retopo / Outer Shell Problems
6 hours ago, Monsterlutz said:
I often get a problem with the outer shell when i want to bake the normal map. And this leads to ugly fragments in the normalmap.
The retopo MEsh looks fine. The voxel mesh too.
I do not find the problem. What do i do wrong?
The Bake Scan Setting Tool remembers the last painting of the projection cage setting of the previous file... Click on the Reset tab in the tool's panel.
Your in and out settings will not change, this you will need to set for your current model but the painted projections will be returned to normal according to your current retopo mesh
Edited by digman
  • New Member
Reset did it... Thank you.
Shame i did not try this myself...
