New Member uvmapping Posted July 3, 2017 New Member Report Share Posted July 3, 2017 Hello, I'm new to 3d coat and i've been doing some retopology to my head mesh which i've imported from my scanner. while doing the retopology I used the symetry option and when i've unwrapped it it was just half of the face and when I tried to export it to blender it was the same. what should i do in order to get a full head unwraped either in 3d coat or blender? does it have to do with using symetry? if it does how can i avoid it and still not retopology the all mesh by hand? would appreciate any advice . Thank you. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted July 3, 2017 Contributor Report Share Posted July 3, 2017 In the Retopo room, Retopo menu>Apply symmetry Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted July 3, 2017 Reputable Contributor Report Share Posted July 3, 2017 (edited) 3 hours ago, Tony Nemo said: In the Retopo room, Retopo menu>Apply symmetry After doing what Tony said, Go back to the retopo menu and deselect virtual symmetry. The reason that you export only one side of the model is that virutal symmetry is on plus you have not applied the virtual symmetry to real polygons. I generally do not have virtual symmetry on when retopoing. If my model is symmetrical the other side will be created when using real symmetry. I use virtual symmetry for corrections if needed or to duplicate the axis. A heads up. Sometimes when applying virtual symmetry extra polygons can be created along the symmetry line. Check to make sure you do not have any extra polygons after applying symmetry. Edited July 3, 2017 by digman Quote Link to comment Share on other sites More sharing options...
New Member uvmapping Posted July 4, 2017 Author New Member Report Share Posted July 4, 2017 Thank you very much for your much helpfull advices! If I may -another question- Is it possible to do retopology with the original texture of the model so it stays on the model while retopologing andis it possible to unwrap it? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted July 6, 2017 Reputable Contributor Report Share Posted July 6, 2017 (edited) Been on 4th of July holiday... . I will get back to your question later this week... Edited July 6, 2017 by digman Quote Link to comment Share on other sites More sharing options...
