New Member garin2 Posted October 4, 2017 New Member Report Share Posted October 4, 2017 a simple question i have. if i want to extrude all the way around a cylinder how do i do that? when i use extrude tool only one side is affected. turning off "ignore back faces" makes other side pop out. screen grab attached. thank you. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 4, 2017 Report Share Posted October 4, 2017 Hi ! This video is about how to use the posing tool in 3d Coat Quote Link to comment Share on other sites More sharing options...
New Member garin2 Posted October 5, 2017 Author New Member Report Share Posted October 5, 2017 thank you. allow me one more question on pose tool. when you use 'line' mode in pose tool can you lock your lines to perpendiculars angles like holding down 'shift' key in photoshop or any other software? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 5, 2017 Report Share Posted October 5, 2017 Show Grid > Snap to 2D grid could help better. Quote Link to comment Share on other sites More sharing options...
Advanced Member ebitz Posted October 6, 2017 Advanced Member Report Share Posted October 6, 2017 In your menu bar there is an option for "Extrude Direction". Change this from "Average Normal" to "Vertex Normal" and make sure your "Ignore Back Faces" option is turned off for the rectangle draw type. Quote Link to comment Share on other sites More sharing options...
