Member Richard Cesar Posted October 9, 2017 Member Report Share Posted October 9, 2017 This behavior occured sparattically halfway through retopologizing a model. I saved it and reloaded it, it seemed corrected, but then went crazy again when any change was made (ie upon the completion of drawing a rect on the shape. Note that prior to saving, when this happened, going back in history did not remove the problem. snip 1 is what it looks like after loading the previously saved file. snip 2 is what it looks like after I try to make any modification (in this case I was drawing a lone rectangle somewhere, but quad tool does the same.https://pasteboard.co/GO580VQ.png Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Fluffy Posted October 9, 2017 Reputable Contributor Report Share Posted October 9, 2017 Firstly you may want to update to a newer version of 3D Coat, there have been quite a lot of changes since 4.7.24. That being said this sounds similar to an issue I've encountered a few times recently where, upon reloading a saved file, the retopo mesh no longer snaps to the surface of the sculpt object. Right-clicking the corresponding layers in the VoxTree and selecting the To Global Space option before trying to adjust the retopo mesh seems to fix it, but the same issue will sometimes reoccur the next time the file is saved and reloaded, despite no alterations being made to the voxel layers in question. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 9, 2017 Report Share Posted October 9, 2017 Is Virtual Mirror Mode off ? Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted October 9, 2017 Contributor Report Share Posted October 9, 2017 Got it sometimes on older versions. Click on symmetry and go to paint room!!! , then come back if its not auto fixed click again on the symmetry and it will be fixed. Quote Link to comment Share on other sites More sharing options...
