Member vertigo262 Posted October 17, 2017 Member Report Share Posted October 17, 2017 Since version 4.7.06 I think there was some kind of change or could be a glitch but probably not because I have the same problem with every newer version. When I select a smart material to paint with. For example, Dirt with 2.4 degree in shadow. The older version would paint with transparancy to create dirt or dust. In the newer versions, transparency is not working as it just paints over the existing paint without transparency. The opacity itself works, but nothing with the degree of transparency. I messed around for a while changing things like paint brush to airbrush and sometimes it worked and sometimes not. Then I couldn't get it working again. I am assuming their is a new feature I need to use, but I am not sure what is going on or if it's a bug in the code. Wondering if anyone knows what is going on, or if I am doing something wrong. If I load up 4.7.06 it works like it did before Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 17, 2017 Report Share Posted October 17, 2017 Hello, Are you using latest version ? Quote Link to comment Share on other sites More sharing options...
Member vertigo262 Posted October 17, 2017 Author Member Report Share Posted October 17, 2017 Yes BRO !!! tried multiple versions up to the latest versions !! on multiple computers, bro Quote Link to comment Share on other sites More sharing options...
