Member kwhali Posted November 23, 2017 Member Report Share Posted November 23, 2017 This auto uv map feature 3D coat looks very good! One small issue was in noisy areas of mesh it made many small islands, I am wanting to just uv unwrap the broader/bigger surfaces automatically as a starting point. Is there anyway to control the result so that islands must be of a min size/cluster? Or must I go through afterwards and find all these tiny islands to merge/weld them back manually afterwards? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 23, 2017 Report Share Posted November 23, 2017 There isnt anyway to control the result so that islands must be of a min size/cluster. 0002112: Auto Seem creating too many islands. Below Auto Seams there is another tool - Sharp seams Help to solve this task ? ------------------------------------------ Add Clusters tool (Add Cluster then unwrap) Use the LMB to add a cluster center directly on a polygon face. Clicking again on the same face will remove it. This tool lets you mark local selections of polygons, or clusters, and marks the bordering edges of these clusters as UV Seams, allowing for a whole UV island to be split into parts with little work. 1 Quote Link to comment Share on other sites More sharing options...
Member kwhali Posted November 23, 2017 Author Member Report Share Posted November 23, 2017 I will try see how well it will work. On the large environment mesh there was some slowness when I tried to alter seams/islands. I had very small islands from automap that would be nice to brush over to remove/merge into the larger island they cut into. Even some we're just a single triangle .. Is it a reasonable feature request for postprocess automap result to remove the small island/cluster sizes? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 23, 2017 Report Share Posted November 23, 2017 Yes, it is. Please remember to send any feature requests to Andrew Shpagin at support@3dcoat.com Thx. 1 Quote Link to comment Share on other sites More sharing options...
