Member alexlivingstone Posted January 5, 2018 Member Report Share Posted January 5, 2018 I've reported this a bunch already. My last resort is posting here. Can anyone help. System; i5 6600K, GTX 1070, 16GB DDR4 This is what keep showing up. Nvidia drivers are up to date. Not sure what the hell is going on. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 5, 2018 Report Share Posted January 5, 2018 Did you report it in the page that pops up after clicking OK? Also for now try using the DX one instead of GL or vice-versa. Quote Link to comment Share on other sites More sharing options...
Member alexlivingstone Posted January 5, 2018 Author Member Report Share Posted January 5, 2018 Yes I did. I also tried both versions. Same result. Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 5, 2018 Reputable Contributor Report Share Posted January 5, 2018 It's not going to help posting the crash report, here. It's best to speak with Andrew, directly by sending this to support@3dcoat.com. Let him know what's happening and what build/OS you are using, etc. Quote Link to comment Share on other sites More sharing options...
Member alexlivingstone Posted January 5, 2018 Author Member Report Share Posted January 5, 2018 Thanks, I did just that. Sorry I can find out how to delete that report. Its rather long so I'd remove it is I could. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 5, 2018 Report Share Posted January 5, 2018 6 minutes ago, alexlivingstone said: Thanks, I did just that. Sorry I can find out how to delete that report. Its rather long so I'd remove it is I could. I'll remove it for you. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 6, 2018 Reputable Contributor Report Share Posted January 6, 2018 BTW, is this happening with a specific scene, or does it also happen when working with something from the Splash Screen (like the robot when choosing Paint on UV/Per Pixel Paint)? Quote Link to comment Share on other sites More sharing options...
Member alexlivingstone Posted January 6, 2018 Author Member Report Share Posted January 6, 2018 Its happening with all attempts. Whether importing my mesh or starting from scratch in an empty scene with sculpting. Its happened while painting, sculpting and Retopo, Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 6, 2018 Reputable Contributor Report Share Posted January 6, 2018 57 minutes ago, alexlivingstone said: Its happening with all attempts. Whether importing my mesh or starting from scratch in an empty scene with sculpting. Its happened while painting, sculpting and Retopo, Try going to your "MyDocs/3D Coat 4.8" directory and delete the OPTIONS.XML file and try to see if that helps. Sometimes that file can get corrupted and cause bug-like behavior. Another thing I would try is to go into your Anti-Virus and Firewall application, and add the 3D Coat.exe file to your EXCEPTION list. It's possible that one of those is red-flagging the app and keeping it from accessing image files and such. I have a GTX 1080 with the latest driver and it's not occurring on my machine (WIndows and build 4.8.08). So, something on your machine is throwing a wrench into this situation. Might also help, by process of elimination, to make sure your Wacom Tablet driver is updated, as well. I had some issues with that, once. 2 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted January 6, 2018 Contributor Report Share Posted January 6, 2018 I agree with all previous posts. 3D Coat for what it gives to the end user DEFINITELY deserves the time you are spending to find and fix this issue. 1 Quote Link to comment Share on other sites More sharing options...
Member alexlivingstone Posted January 6, 2018 Author Member Report Share Posted January 6, 2018 Thanks for the help AbnRanger, Deleting the OPTIONS.XML file has seemed to help. I am about 1.5 hrs into without a crash. I will post again if it happens again. So far so good. Cheers 1 Quote Link to comment Share on other sites More sharing options...
Member alexlivingstone Posted January 6, 2018 Author Member Report Share Posted January 6, 2018 5 hours ago, Michaelgdrs said: I agree with all previous posts. 3D Coat for what it gives to the end user DEFINITELY deserves the time you are spending to find and fix this issue. I can see what you mean! It seems rather broad and powerful and comparatively inexpensive. Definitely Digging deeper into it. Thanks 1 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted January 6, 2018 Contributor Report Share Posted January 6, 2018 Keep it up , anything you need we are here to help. Quote Link to comment Share on other sites More sharing options...
