New Member 3d-designer Posted January 26, 2018 New Member Report Share Posted January 26, 2018 When I resize window from full screen to any size, 3d Coat crashes every time and is repeatable. But only if I have a painted object in workspace. I have a unique setup I think, which may be why problem not found before. Here is my computer configuration: Windows 10 latest build. 32 GB of ram. i7-3770k. Special monitor connections: Two Gigabyte Nvidia GTX970 gaming cards. Two 4k monitors. Nvidia cards NOT in SLI. Each monitor is connected to its own card. Any suggestions as to what could be causing this? It behaved same way before latest Windows 10 update. No other application has this problem, ie. Unity3d or Blender. Quote Link to comment Share on other sites More sharing options...
New Member 3d-designer Posted February 1, 2018 Author New Member Report Share Posted February 1, 2018 no one has answer to this problem? Quote Link to comment Share on other sites More sharing options...
New Member 3d-designer Posted February 24, 2018 Author New Member Report Share Posted February 24, 2018 I used windows 10 trouble shooter and it determined it had to run in windows 8 compatibility mode. Both GL and DX versions of the program behaved the same way. This is for version 4.10.7 and 4.8.19. So problem is solved Quote Link to comment Share on other sites More sharing options...
