Member jaros Posted March 17, 2018 Member Report Share Posted March 17, 2018 Hi, i'm a new to 3d coat and just trying things out with version 4.8.10. I was following a tutorial whre a guy used the extrude voxel tool in voxel mode to paint some rough details into his voxel object. Unfortunately the extrude tool stops working with any "freehand" stroke mode when i subdivide the voxel object (by pressing Res+). It works however with the rectangular, circle, lasso etc ... You can test this: 1) Start a new Voxel scene with the small sphere. Choose the Extrude tool (Voxel tools). Take the first stroke mode on the stoke mode panel. Paint over the sphere. It works! 2) Subdivide the sphere by pressing the Res+ button. Try to paint with the Extrude tool with any "freehand" stroke mode again (any on the left side until square lasso). Its not working anymore... I found a workaround for the simple voxel sphere scene: you have to increase the object size in the voxtree...then the extrude tool starts to work again... But it seems like a bug to me cause all other voxel tools work fine after subdivision. Anyone got the same behavior! Quote Link to comment Share on other sites More sharing options...
Member jaros Posted March 17, 2018 Author Member Report Share Posted March 17, 2018 I installed an older version (4.7.38Y) and its works like it should! You can use all stroke modes with the voxel extrude tool at any resolution without any problems. Seems to me like bug in 4.8.... Quote Link to comment Share on other sites More sharing options...
Member jaros Posted March 17, 2018 Author Member Report Share Posted March 17, 2018 Ok, did some further tests and it seems that version 4.8.08 is the last version the voxel extrude tool worked without any problems... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2018 Report Share Posted March 17, 2018 Hi Im testing 4.8.13 and is working without any troubles. Can you take a look please ? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 17, 2018 Reputable Contributor Report Share Posted March 17, 2018 It was broken a few beta version ago and as Carlosan pointed out it is now fixed. Quote Link to comment Share on other sites More sharing options...
Member jaros Posted March 17, 2018 Author Member Report Share Posted March 17, 2018 Thank you, guys! You are right! In version 4.8.13 voxel extrude works like a charm again Cheers! Quote Link to comment Share on other sites More sharing options...
