3D Coat Forums
blackant Master
[SOLVED]Degenerated Mesh and UVs
Hello,
this bug is happening actually often, (3dc 4.8.15(DX64))
lets explain it:
- i do my model in max, using splines and edit poly,
- i export them to Zbrush, modify it in High res and can sometimes export back the low res when the mesh is not to much modified
- once my High res model is done i explode each part into max and fit each low res part over it
- i export high res version and low res version for retopo
- inside 3dc, i import high res mesh a reference mesh and low res inside retopo room
- now i can start working retopo by layers, and sometimes i must add some edge loops to my model, so i use Split Rings
- i get this:
5ad0a7a3dd007_Screenshotat2018-04-13143553.thumb.png.2dea89d17f44b8196ca06bf2b11aafaf.png
- this part doesn't work, i'm unable to Clear seams and rework them nicelly, doing it manually (Ctrl+clic) doesn't work, but works on unbroken parts
- i exported the mesh to max and reimported it, and get no change at all
- i tryed to merge vertices, it works, they are not splited
- but if i come back to my topology and cut this part, the UV are broken another time:
Edited by blackant Master
solved
Another case,
following the sae workflow, but this time, i take the time to unwrap my mesh before anything else:
5ad0ac08e555c_Screenshotat2018-04-13150727.thumb.png.dad42dfe517c97236ba7558ea324539e.png
- This time the Unwrap is clean, but saddly i need more edgeloops at the end of my object, so i need to split it again:
5ad0ac651b289_Screenshotat2018-04-13150749.thumb.png.a44fb76db163a85e0fab0e6b1bf36a59.png
-and if i put my mose over any next edgeloop i would like i can see clearly that it will not be what i espect:
5ad0ac99c9b20_Screenshotat2018-04-13150815.thumb.png.02b135d9083f09d40baede8eb6e53522.png
