3D Coat Forums
TLE
Tubes/Array Tool Meshes instance, editable?
Tubes/Array tool is awesome dued to it none destructive. However, it would be way better if the meshes are instanced. (or they are?). And ability to have a mesh edit button in tool option to load the mesh up in different window and alter it and see the changes on the tube.
Also just found out that, it won't allow me to copy the tool option setting from one curves to an other. It would be nice able to do that. (took lot of time to set up one tubes correct and after that, draw a bunch of other tubes and transfer the setting to all tubes). EDIT. Never mind for this part, I found out that you just copy each properties and select other layer and just paste it in. take little bit time but it can be done.
Edited by TLE
