[Solved] Retopo symmetry bug ?
Spacetime
I watched the video.  Possible bug... In 3DC under the Help menu, you can send the file to support. Explain the problem and a link to your thread.  If you would like me to look at the problem as well, pm me with link to your 3DC file.
Some FYI information.
Thin areas like at the edge of the blade are at times problematic when retopoing. I even turn off auto snap when I need to and adjust by hand.
 I generally do not use virtual symmetry around thin areas. Virtual  symmetry works best on areas that are thicker. My own workflow does not use virtual symmetry very much. I will explain below.
Real symmetry will do everything that virtual symmetry will do as long as the model is symmetrical. The other symmetrical side will be built out as well.
You can also use the symmetry commands highlighted in the picture with real symmetry.
  • Carlosan changed the title to [Solved] Retopo symmetry bug ?
